Actualizados todos los OSCam:
- OSCam a 11505.
- OSCam_pcsc a 11505.
- OSCam_modern a 11505 r790.
Se ha añadido nuevamente las opciones Cache exchange support y constant CW, el que las use que comente si van bien.
Lo nuevo:
Cambios 11505
- dont overwrite demux_index if demuxid >0
Cambios 11504
- to make people be happy ...
No "dummy" Leete las normas reader included at all in oscam
and no sign of Leete las normas in the webif
Removed WITH_EMU and WITH_SOFTCAM options from
:config.sh, makefile, cmakelists.txt and config.h
Some Leete las normas specific code parts remain in the source code
and can be activated only after patching with the Leete las normas reader
Cambios 11503
- this patch includes:
A. make, cmake and config parameters.
This means that we have 2 new options:
WITH_EMU to enable/disable the (dummy) Leete las normas reader, and
WITH_SOFTCAM to enable/disable linking of softcam.key inside the binary.
The WITH_SOFTCAM option can be removed completely if you like.
No code that reads keys is included.
B. All webif changes are included.
This means that when building WITH_EMU enabled,
there will be a stream relay page and
an Leete las normas reader "config bit" in the reader settings.
There will also be a softcam.key link
to open the softcam.key file and see its content
(similar to what is done in constant.cw file).
C. When building with disabled WITH_EMU,
there will be no sign of Leete las normas reader anywhere.
Cambios 11502
- fix some bugs
- insert hd03 and hd04 atr
