Cambios 11504
- to make people be happy ...
No "dummy" camd reader included at all in oscam
and no sign of camd in the webif
Removed WITH_EMU and WITH_SOFTCAM options from
:config.sh, makefile, cmakelists.txt and config.h
Some camd specific code parts remain in the source code
and can be activated only after patching with the camd reader
Cambios 11503
- this patch includes:
A. make, cmake and config parameters.
This means that we have 2 new options:
WITH_EMU to enable/disable the (dummy) camd reader, and
WITH_SOFTCAM to enable/disable linking of softcam.key inside the binary.
The WITH_SOFTCAM option can be removed completely if you like.
No code that reads keys is included.
B. All webif changes are included.
This means that when building WITH_EMU enabled,
there will be a stream relay page and
an camd reader "config bit" in the reader settings.
There will also be a softcam.key link
to open the softcam.key file and see its content
(similar to what is done in constant.cw file).
C. When building with disabled WITH_EMU,
there will be no sign of camd reader anywhere.
Cambios 11502
- fix some bugs
- insert hd03 and hd04 atr
Cambios 11501
- complete remove of cardlist.c + cardlist.h
Cambios 11500
- this is expected to be the last cleanup patch
Cambios 11499
- fiy small inconsistencies in config.h/config.sh
Cambios 11498
- fix bbuild for make & cmake
disable writing of empty keys
Cambios 11497
- fix reset to wrong defaults
Cambios 11496
- clean implementation of the card list
- rarely used modules are set from default on to default off (no codechange just setup switch)
Cambios 11495
- small acosc fix
Cambios 11494
- small fix for build without webif
Cambios 11493
- old compiler dont like passive #pragma comments
Cambios 11492
- eliminate build warnings by using the integrated function
cs_strncpy instead of strncpy
Cambios 11491
- extended fix for orf global emm
dont disable global emms or set in config blockemm-g = 0
caid 0x0D96 & 0x0D98
thnx to all testers and support on digital-eliteboard
Cambios 11490
- fix last commit missing ;
Cambios 11489
- some cleanups for newcamd
and add script for git svn diff creation
Cambios 11488
- fix typo in mca build
thanks sattotal
Cambios 11487
- enhance function anticascading or SIDs count
Cambios 11486
- add UPC Hungary support & clean up
Cambios 11485
- Fix NAN % in READERS ECM INFO
thnx Optimum Power
Cambios 11484
- enhancement #4662
by Jotne
show number of cards in the log
Cambios 11483
- fix small typo
move log to debug #4664
Cambios 11482
- fix #4692 for missing values in ecminfo_type = 3
by Optimum Power
Cambios 11481
- small cleanup
CMakeLists.txt
Makefile
Cambios 11480
- big update pack 5
another cleanup &
removed duplicate functions
Cambios 11479
- unified presentation
of tabs and spaces
Cambios 11478
- big cleanup pack 4
Cambios 11477
- another buildwarning fix
!!! SAMYGO User !!! report any issue
Cambios 11476
- fix 4 build warnings
Cambios 11475
- fix another small build warning
Cambios 11474
- fix cmake compiler warning
Cambios 11473
- big cleanup pack 3
Cambios 11472
- big cleanup & bugfix for all warnings for gcc 7.2+
Cambios 11471
- cleanup module-dvbapi.c
Cambios 11470
- Cleanup and add functions
Cambios 11469
- fix warnings in #11468
Cambios 11468
- another cleanup patch
Cambios 11467
- small cleanup in cscrypt
+ adding libs
Cambios 11466
- set demuxer stop point if PMT demux_index == 0
found by schwa226
Cambios 11465
- Changeset:
fix Nagra & Nagra Merlin Tier Expire Dates
Nagra EMM Filter merged
Nagra Merlin Code cleanup
completeness check of the required CAK7 keys
Block NAD changes reverted
fix xxor fallthrough
aescbc removed
tabs / comments / spaces cleanup
thnx kabeltod
Cambios 11464
- tryfix
Cambios 11463
- part1 cleanup and fixes for gcc 8.2
Cambios 11462
- fix last commit
Cambios 11461
thnx optimum power
Cambios 11460
- code cleanup and fix for NDS Standard cards
thnx to KD (de-board)
Cambios 11459
- fix typo missing ;
Cambios 11458
- fix 1x fallthrough / break videoguard2 cleanup
Cambios 11457
- part 2 for ORF AU fix
-add CAID 0D96
-add on/off switch
thnx to pehedima
Cambios 11456
- [gbox] fix oscam crash when enable ccc to gbx share
Cambios 11455
- add support for VideoGuard? BSkyB (0960) entitlement date
Cambios 11454
- I send the FEDC patch for polish seca cards.
It was made by: Jej@n and ketanol
Cambios 11453
- created functions for detecting caid. "tandberg" is renamed to "director", because tandberg is the compary and director is the CA system.
by Nautilus7
Cambios 11452
- some dvbapi cleanups (but there's more to do.)
- whitespace clean up
Cambios 11451
- fix for last commit ...
Cambios 11450
- !!!! Better stream type identification based on descriptors
OSCam now detects the type of each stream pid (video, audio, subtitle, etc) based, not only on the "stream_type" value in the PMT, but on the stream descriptors as well. Stream type detection is crucial when using the extended cw and this patch fixes many problems with PowerVu? channels which had no working audio streams. Stream type detection is now done once and is the same whether the "simple" cw or the extended cw are used.
all based on Nautilus7 great JOB !!!!
Cambios 11449
- fix orf cards (0D98) au if global is blocked
based on pehedima fix digital-eliteboard
Cambios 11448
- better solution streamid
thnx Nautilus7
Cambios 11447
- Tryfix for Powervu
by Nautilus7
Cambios 11446
[gbox] - Speed up local card status detection and report cards to Leete las normas
Cambios 11445
- fix for ticket #4699 - add tandberg to 'get cardsysten' in oscam.simples.c
- fix for ticket #4700 - add #include <sys/sysmacros.h> to globals.
Cambios 11444
[gbox] - fix peer password not stored in config
Cambios 11443
[gbox] - fix parameter 'gbox_reshare'
- show peer-id & online stat in webif reader
- code clear up
Cambios 11442
-fix compiler issue when build without gbox
Cambios 11441
[gbox]
- improve REMM feature
- show remm req in webif
- gbx webif cosmetics/improvements
- fix typos from r11437 thx sattotal
- remove ccc stuff from gbx page when ccc not compiled in
- webif: display 'use_gpio' on physical readers only
Cambios 11440
[nagra merlin]
- fix some compiler errors and warnings introduced r11429
- patch provided by DaMulda?
Cambios 11439
-Enables Nagra Merlin (CAK7) reader by default
-Corresponding keys are now configurable via WebIf and config files
Cambios 11438
-[gbox webif]
- dont show cccam stuff in gbx reader page
Cambios 11437
-[gbox webif]
- make webif more gbx friendly
- gbx specific settings not shown on other protocols
- moved 'use_gpio' from smargo to mouse
Cambios 11436
- Fix for tiers with rights set to 0x49xx (tnx tommy76 for research and patch!)
Cambios 11435
- Revert r11164 see ticket #4609 (tnx Tommy76 for researching!)
Cambios 11434
- Fix #4688 not procesing all received emm packets at filter startup tnx xoxo for this patch!
Cambios 11433
- fix DGCrypt Redlight Card not running since r11429
- this fixes ticket #4687
- thx OP and pehedima
- fix mdc2.c compilation with openssl 1.1.x
- thx flk
- fix orf_ice text in cardlist.h
