Actualizados todos los OSCam:
- OSCam a 11464.
- OSCam_pcsc a 11464.
- OSCam_modern a 11464 r785.
Lo nuevo:
Cambios 11464
- tryfix
Cambios 11463
- part1 cleanup and fixes for gcc 8.2
Cambios 11462
- fix last commit
Cambios 11461
- another cleanup patch
thnx optimum power
Cambios 11460
- code cleanup and fix for NDS Standard cards
thnx to KD (de-board)
Cambios 11459
- fix typo missing ;
Cambios 11458
- fix 1x fallthrough / break videoguard2 cleanup
Cambios 11457
- part 2 for ORF AU fix
-add CAID 0D96
-add on/off switch
thnx to pehedima
Cambios 11456
- [gbox] fix oscam crash when enable ccc to gbx share
Cambios 11455
- add support for VideoGuard? BSkyB (0960) entitlement date
Cambios 11454
- I send the FEDC patch for polish seca cards.
It was made by: Jej@n and ketanol
Cambios 11453
- created functions for detecting caid. "tandberg" is renamed to "director", because tandberg is the compary and director is the CA system.
by Nautilus7
Cambios 11452
- some dvbapi cleanups (but there's more to do.)
- whitespace clean up
Cambios 11451
- fix for last commit ...
Cambios 11450
- !!!! Better stream type identification based on descriptors
OSCam now detects the type of each stream pid (video, audio, subtitle, etc) based, not only on the "stream_type" value in the PMT, but on the stream descriptors as well. Stream type detection is crucial when using the extended cw and this patch fixes many problems with PowerVu? channels which had no working audio streams. Stream type detection is now done once and is the same whether the "simple" cw or the extended cw are used.
all based on Nautilus7 great JOB !!!!
Cambios 11449
- fix orf cards (0D98) au if global is blocked
based on pehedima fix digital-eliteboard
Cambios 11448
- better solution streamid
thnx Nautilus7
Cambios 11447
- Tryfix for Powervu
by Nautilus7
