- 2 Mar 2009
- 6.022
- 4.492
Actualizados en descargas los OSCam:
- OSCam_modern a 11487 r785.
Cambios 11487
- enhance function anticascading or SIDs count
Cambios 11486
- add UPC Hungary support & clean up
Cambios 11485
- Fix NAN % in READERS ECM INFO
thnx Optimum Power
Cambios 11484
- enhancement #4662
by Jotne
show number of cards in the log
Cambios 11483
- fix small typo
move log to debug #4664
Cambios 11482
- fix #4692 for missing values in ecminfo_type = 3
by Optimum Power
Cambios 11481
- small cleanup
CMakeLists.txt
Makefile
Cambios 11480
- big update pack 5
another cleanup &
removed duplicate functions
Cambios 11479
- unified presentation
of tabs and spaces
Cambios 11478
- big cleanup pack 4
Cambios 11477
- another buildwarning fix
!!! SAMYGO User !!! report any issue
Cambios 11476
- fix 4 build warnings
Cambios 11475
- fix another small build warning
Cambios 11474
- fix cmake compiler warning
Cambios 11473
- big cleanup pack 3
Cambios 11472
- big cleanup & bugfix for all warnings for gcc 7.2+
Cambios 11471
- cleanup module-dvbapi.c
Cambios 11470
- Cleanup and add functions
Cambios 11469
- fix warnings in #11468
Cambios 11468
- another cleanup patch
Cambios 11467
- small cleanup in cscrypt
+ adding libs
Cambios 11466
- set demuxer stop point if PMT demux_index == 0
found by schwa226
Cambios 11465
- Changeset:
fix Nagra & Nagra Merlin Tier Expire Dates
Nagra EMM Filter merged
Nagra Merlin Code cleanup
completeness check of the required CAK7 keys
Block NAD changes reverted
fix xxor fallthrough
aescbc removed
tabs / comments / spaces cleanup
thnx kabeltod
Cambios 11486
Cambios 11485
thnx Optimum Power
Cambios 11484
- enhancement #4662
by Jotne
Cambios 11483
- fix small typo
Cambios 11482
by Optimum Power
Cambios 11481
- small cleanup
CMakeLists.txt
Makefile
Cambios 11480
- big update pack 5
another cleanup &
Cambios 11479
of tabs and spaces
Cambios 11478
Cambios 11477
Cambios 11476
Cambios 11475
Cambios 11474
Cambios 11473
Cambios 11472
Cambios 11471
Cambios 11470
Cambios 11469
Cambios 11468
Cambios 11467
+ adding libs
Cambios 11466
found by schwa226
Cambios 11465
- Changeset:
aescbc removed
thnx kabeltod
