Puerto RS232 y Consola YAMON y la FLASH del Azbox
afrarex
6 Ago 2010
29
Hola compis, despues de un año con el azbox como posapapeles, he decidido intentar arreglarlo, pero no consigo pasar del paso 5.
cuando pongo:
YAMON> load -b tftp://192.168.1.131/vmlinux.bin 0x90020000
sale:
About to load tftp://192.168.1.131/vmlinux.bin
Press Ctrl-C to break
re-configuring ..
em86xx_eth: auto-negotiation failed.
em86xx_eth:eek:pen(em86xx_eth) - no link
em86xx_eth ethernet start
no link, please check cable
Error : Internal, code = fffffffb
¿Alguien me puede ayudar? gracias por anticipado.
afrarex
6 Ago 2010
29
Hola compañeros, ¿alguien le puede echar un vistazo a esto?, ya no se que hacer. Gracias.
dram1 ok (9)
zboot (0) ok
* SMP863x zboot start ...
* Version: 2.4.0-2.8.0.1
* Started at 0x91000000.
* Configurations (chip revision: 6):
* Use 8KB DRAM as stack.
* Support XLoad format.
* Enabled BIST mode.
* Enabled memory test mode.
* Use internal memory for stage0/1.
Boot from flash (0x48000000) mapped to 0x8c000000.
Found XENV block at 0x8c000000.
CPU clock frequency: 300.37MHz.
System clock frequency: 200.25MHz.
DRAM0 dunit_cfg/delay0_ctrl (0xf34111ba/0x000b8888).
DRAM1 dunit_cfg/delay0_ctrl (0xf34111ba/0x000a7776).
Using UART port 0 as console.
Board ID.: "852-E2"
Chip Revision: 0x8634:0x86 .. Matched.
Setting up H/W from XENV block at 0x8c000000.
Setting <SYSCLK avclk_mux> to 0x00000000.
Setting <SYSCLK hostclk_mux> to 0x00000100.
Setting <IRQ rise edge trigger lo> to 0xff28ca00.
Setting <IRQ fall edge trigger lo> to 0x0000c000.
Setting <IRQ rise edge trigger hi> to 0x0000009f.
Setting <IRQ fall edge trigger hi> to 0x00000000.
Setting <IRQ GPIO map> to 0x20090820.
Setting <PB default timing> to 0x10101010.
Setting <PB timing0> to 0x10101010.
Setting <PB Use timing0> to 0x000003f4.
Setting <PB timing1> to 0x00110101.
Setting <PB Use timing1> to 0x000003f3.
Setting <PB timing2> to 0x105f1010.
Setting <PB Use timing2> to 0x000003f8.
PB cs config: 0x000e0040 (use 0x000e0040)
Enabled Devices: 0x00021ace
BM/IDE PCIHost Ethernet I2CM I2CS USB PCIDev2 PCIDev3 SCARD
MAC: 00:02:14:18:33:16
PCI IRQ routing:
IDSEL 2: INTA(#14) INTB(#14) INTC(#14) INTD(#14)
IDSEL 3: INTA(#15) INTB(#15) INTC(#15) INTD(#15)
Smartcard pin assignments:
OFF pin = 0
5V pin = 1
CMD pin = 2
Setting up Clean Divider 2 to 96000000Hz.
Setting up Clean Divider 4 to 33333333Hz.
Setting up Clean Divider 5 to 25000000Hz.
Setting up Clean Divider 6 to 20000000Hz.
Setting up Clean Divider 7 to 20000000Hz.
GPIO dir/data = 0x76000038/0x76000000
UART0 GPIO mode/dir/data = 0x6e/0x00/0x00
UART1 GPIO mode/dir/data = 0x6e/0x00/0x00
XENV block processing completed.
Found existing memcfg: DRAM0(0x08000000), DRAM1(0x08000000)
Heap/Temp/Temp1/Dest start at 0x14000000/0x16000000/0x15000000/0x12000000.
Default boot index: 0
Scanning ROMFS image at 0x8c040000 (0x48040000) .. Found.
ROMFS found at 0x8c040000, Volume name = YAMON_XRPC
Found 1 file(s) to be processed in ROMFS.
Processing xrpc_xload_yamon_ES4_prod.bin (start: 0x8c040090, size: 0x0002fe84)
Checking zboot file signature .. Not found.
Trying xrpc_xload format .. OK
Checking zboot file signature at 0x13000000 .. OK
Decompressing to 0x91200000 .. OK (453328/0x6ead0).
Load time total 173/255 msec.
Execute final at 0x91200000 ..
* YAMON ROM Monitor
* Revision 02.06-SIGMADESIGNS-01-2.8.0.1
Memory: code: 0x11000000-0x11040000, 0x11200000-0x11204000
reserved data: 0x11240000-0x12440000, PCI memory: 0x12440000-0x12840000
Environment variable 'start' exists. After 1 seconds
it will be interpreted as a YAMON command and executed.
Press Ctrl-C (or do BREAK) to bypass this.
YAMON> setenv bootserver 192.168.1.131
Updating XENV block at 0x48000000.
XENV verification OK.
YAMON> setenv gateway 192.168.1.1
YAMON> setenv ipaddr 192.168.1.55
YAMON> setenv subnetmask 255.255.255.0
YAMON> net init
Ethernet driver for EM86XX (v1.0)
(MAC 00:02:14:18:33:16, tx_desc/rx_desc = 16/32)
ipaddr: 192.168.1.55
subnetmask: 255.255.255.0
gateway: 192.168.1.1
YAMON> net up
re-configuring ..
26 Ago 2009
8.533
2.650
El servidor tftp no está operativo, vamos que no encuentra la ip donde está el archivo vmlinux.bin
Asegurate que ningun antivirus y ningun firewall te está bloqueando el acceso.
afrarex
6 Ago 2010
29
Gracias por tu respuesta darkmantk, tengo desactivado el antivirus y el firewall de windows, pero nada, ¿el tftpd32 solo tiene que estar abierto con la direccion donde esta Files y con la ip de mi ordenador para que el deco se comunique con el? o ¿tengo que hacer algo mas?
Un saludo.
abdelsat
OpenSpa VIP
21 Ene 2008
2.783
361
Si no te funciona el Tftpd32, utiliza el pumpkin hace lo mismo, mírate esta manual
http://www.azboxhd.es/foro/topic/14112-tutorial-recuperar-azbox-via-yamon/
afrarex
6 Ago 2010
29
Nada, no hay forma de que el azbox contacte con el pc, esta desactivado el antivirus y el firewall pero nada, no se donde estoy fallando.
pe.tardo
Miembro de honor OpenSpa
21 May 2009
3.474
464
BCN
Hola. En mi caso completo to el proceso, pero no puedo loguearme. Me dice login incorrecto. He probado con root/vacio, root/azbox, etc, etc y no funciona. Nunca he cambiado la contraseña por defecto. ¿que puedo hacer?
Te borro este post porque ya te han contestado en el otro hilo.
mazurin18
18 Dic 2014
Despues de darme cuenta lo he corregido y la ventana del Terminal de Putty si se abria pero cuando tecleaba para escribir los comandos me salian algunas letras en forma de simbolos. Luego de cambiar de la portable a PC1 con Win7 y luego a PC2 con WinXP la cosa seguia igual. Luego he cambiado el adaptador y empezo a sonreir mi Deco, los signos que tecleaba eran reales y fluido. Luego procedi a mandar los comandos como en el manual lo indica
"Luego he cambiado el adaptador y empezo a sonreir mi Deco"
Con que adaptador nuevo?
ardilla99
VIP surfero
12 Mar 2009
1.313
116
Alpes
Hola mazurin, tienes que leer todo el Tema. En el thread #37 he puesto mas informacion sobre ese Adaptador
Aquella vez habia pedido dos adaptadores y uno me lo mandaron fallado y por eso estaba teniendo problemitas aquella vez. Ahora no me acuerdo muy bien como lo he hecho porque el amigo abdelsat me hecho una mano remotamente en la parte final del flasheo.
Suerte y saludos
