Nuevo loadepg que funciona en los ultimos firms
moicas3004
15 Ago 2009
35
hfmls dijo:
el channels.map esta ok?
XMLTV:www.xmltvepg.be/rytecxmltvportugal.gz:/PLUGINS/PanelKGD/epg/PTxmltv.xml
# (Abril-2010, Fundidun)
# Portugal EPG Example
#Hispasat 13º
#canal : SAT:NID:TID: frec: SID: POLARIDADE
#MEO
BenficaTV.pt:152:83:103:12092000:305:0
venus.pt:152:83:101:12012000:123:0
#tvcabo (zon)
aljazeera.pt:152:54:40:11577000:794:1
arte.pt:152:54:39:11891000:768:0
axn.pt:152:54:37:12012000:712:1
axn.pt:152:54:47:11731000:950:1
babyfirst.pt:152:49:9:12149000:3001:1
BBCentertainment.pt:152:54:42:11771000:895:0
bbcworldnews.pt:152:54:37:12012000:717:1
HistoryChannel.pt:152:54:40:11577000:933:1
canalpanda.pt:152:54:37:12012000:218:1
cartoon.pt:152:54:38:11851000:307:0
cartoon.pt:152:54:42:11771000:969:0
cazaepesca.pt:152:54:42:11771000:970:0
cnbc.pt:152:54:37:12012000:961:1
cnn.pt:152:54:37:12012000:962:1
discoverychannel.pt:152:54:41:11617000:603:1
discoverycivilization.pt:152:54:40:11577000:780:1
discoveryscience.pt:152:54:40:11577000:781:1
DiscoveryTravelLiving.pt:152:54:37:12012000:704:1
discoveryturbo.pt:152:54:40:11577000:779:1
disneycinemagic.pt:152:50:13:12092000:846:1
eentertainment.pt:152:54:42:11771000:942:0
nasnespnamerica.pt:152:54:41:11617000:959:1
euronews.pt:152:54:37:12012000:702:1
eurosport.pt:152:54:38:11851000:312:0
eurosporthd.pt:152:54:47:11731000:949:1
eurosportnews.pt:152:54:39:11891000:769:0
extremesportschannel.pt:152:54:39:11891000:963:0
fashiontv.pt:152:54:39:11891000:936:0
fox.pt:152:54:41:11617000:972:1
fox.pt:152:54:47:11731000:802:1
foxcrime.pt:152:54:41:11617000:974:1
foxlife.pt:152:54:42:11771000:705:0
foxlife.pt:152:54:47:11731000:803:1
FoxNext.pt:152:54:41:11617000:608:1
france24.pt:152:54:37:12012000:720:1
fx.pt:152:54:41:11617000:975:1
hollywood.pt:152:54:38:11851000:313:0
Hot.pt:152:54:37:12012000:831:1
m6.pt:152:54:40:11577000:939:1
mcmtop.pt:152:54:42:11771000:894:0
mezzo.pt:152:54:37:12012000:965:1
mov.pt:152:54:39:11891000:777:0
movhd.pt:152:54:47:11731000:944:1
mtvdance.pt:152:54:40:11577000:783:1
mtvmusic.pt:152:54:40:11577000:782:1
mtvportugal.pt:152:54:40:11577000:504:1
mtvtwo.pt:152:54:37:12012000:967:1
nationalgeographic.pt:152:54:40:11577000:968:1
nationalgeographichd.pt:152:54:47:11731000:943:1
NBA.pt:152:54:41:11617000:609:1
nickelodeon.pt:152:54:42:11771000:701:0
odisseia.pt:152:49:9:12149000:3002:1
PandaBiggs.pt:152:54:36:11811000:102:0
pfc.pt:152:54:42:11771000:903:0
playboytv.pt:152:54:38:11851000:169:0
portocanal.pt:152:54:38:11851000:304:0
raiuno.pt:152:54:39:11891000:770:0
rtl.pt:152:54:39:11891000:764:0
rtp1.pt:152:54:36:11811000:811:0
rtp1.pt:152:54:47:11731000:946:1
rtp2.pt:152:54:36:11811000:812:0
rtpAfrica.pt:152:54:40:11577000:503:1
rtpmemoria.pt:152:54:38:11851000:310:0
rtpn.pt:152:54:36:11811000:101:0
sic.pt:152:54:36:11811000:813:0
sicmulher.pt:152:54:37:12012000:703:1
sicnoticias.pt:152:54:36:11811000:801:0
sicradical.pt:152:54:40:11577000:502:1
skynews.pt:152:54:37:12012000:966:1
SonyTV.pt:152:54:39:11891000:403:0
sporttv1.pt:152:54:38:11851000:870:0
sporttv2.pt:152:54:38:11851000:301:0
sporttv3.pt:152:54:38:11851000:306:0
SportTVGolfe.pt:152:54:37:12012000:219:1
sporttv1hd.pt:152:54:47:11731000:945:1
Biography.pt:152:54:42:11771000:890:0
TravelChannel.pt:152:54:41:11617000:601:1
tvgalicia.pt:152:54:39:11891000:774:0
tvgloboportugal.pt:152:54:42:11771000:904:0
tvrecord.pt:152:1:14:11972000:24:1
tv5monde.pt:152:54:39:11891000:765:0
tvc1.pt:152:54:39:11891000:402:0
tvc2.pt:152:54:42:11771000:700:0
tvc3.pt:152:54:41:11617000:607:1
tvc4.pt:152:54:39:11891000:776:0
tvc4.pt:152:54:47:11731000:947:1
TVEi.pt:152:54:39:11891000:762:0
TVI.pt:152:54:36:11811000:814:0
TVI24.pt:152:54:38:11851000:305:0
vh1.pt:152:54:37:12012000:785:1
vh1classic.pt:152:54:42:11771000:891:0
yachtsail.pt:152:54:41:11617000:600:1
zonereality.pt:152:54:41:11617000:604:1
Não podes usar esse. tens de usar no inicio o ficheiro da rytec mas não é esse.
Eu vou fazer uns testes agora e depois digo-te.
7.257
1.396
El archivo esta mas o menos bien, la primera linea tienes que modificar quitando el http:// de la url. Por ejemplo:
XMLTV:www.xmltvepg.be/rytecxmltvdplus.gz:/DATA/usb1/sda1/XMLTV/rytecxmltvdplus
En rojo la url del xml y en azul la ruta donde se guardara. Este ejemplo me usaria el xml para dplus y lo guardaria en una carpeta XMLTV del usb.
hfmls
6 Abr 2009
898
www.satelites.info
me da este error:
AZBox[epg]$ ./loadepg
epgKGD 0.5 for AZboxHD by morser
unlink fail!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!: No such file or directo
ERROR: link...[3][0]-n_in 0, on 0, ts 0, freq 0, sid 0, polr 0
ERROR: link...[3][1]-n_in 0, on 0, ts 0, freq 0, sid 0, polr 0
ERROR: link...[3][2]-n_in 0, on 0, ts 0, freq 0, sid 0, polr 0
ERROR: link...[3][3]-n_in 0, on 0, ts 0, freq 0, sid 0, polr 0
ERROR: link...[3][4]-n_in 0, on 0, ts 0, freq 0, sid 0, polr 0
ERROR: link...[3][5]-n_in 0, on 0, ts 0, freq 0, sid 0, polr 0
__________________________________________
en standby:
ERROR: TVSDK_GetEvent:307 timeout !! cmd 0xb6
ERROR: TVSDK_Init:373 fail to receive b6
ERROR: TVSDK_GetEvent:307 timeout !! cmd 0x40
ERROR: TVSDK_GetEITMemoryStatus:1166 fail to receive 40
7.257
1.396
Tiene pinta de que tienes algun error en la lista de canales pero continua, o no?
En el segundo caso ya veo que te estan saliendo errores de timeout, cuando sale eso lo mejor es reiniciar porque te va a ir lentisimo y al final se colgara, eso pasa a veces.
7.257
1.396
Os paso la version 0.6. Lo unico que cambia es que se ha compilado con el nuevo SDK y ya no se machaca el programa actual y el siguiente que metemos con el plugin.
  • epgKGD 0.6.zip
    12,4 KB · Visitas: 67
The_Doc
4 Ago 2009
303
Seria alguien tan amable de subir un channels.map para Astra 19.0E? si es posible que sea actual Pliss, no se algo me falla, con la version anterior me carga el EPG perfectamente, con este solo la mitad de canales si es que llega y ya no se si este archivo lo tengo mal o no..
madomape
14 Feb 2009
946
45
Funciona a las mil maravillas, como siempre, morser. Mil gracias. Efectivamente ahora ya no machaca el programa actual y el siguiente.
x jaleman. Aquí te dejo mi channels.map para Astra. Está probado y actualizado. Espero que te sirva.
The_Doc
4 Ago 2009
303
Gracias madomape, este channel.map tuyo tiene creo que 40 canales mas que el que yo tenia instalado ;-)
hfmls
6 Abr 2009
898
www.satelites.info
alguien sabe porque este error?
epgKGD 0.6 for AZboxHD by m
Segmentation fault
AZBox[epg]$
L
linarense
hfmls dijo:
Segmentation fault
AZBox[epg]$
Estas usando un Pendrive USB??? si es asi recuerda formatearlo con el propio deco y no en fat32.
Salu2!!!
7.257
1.396
mira, porcede asi:
1 - Mete los dos archivos en /PLUGINS/PanelKGD/epg/ (no puede estar en otra carpeta y cuidado con las mayusculas y minusculas)
2 - Permisos 755 a los dos archivos
3 - Mete en la misma carpeta tu channels.map
4 - Como creo que el xml de portugal ocupa mucho lo mejor seria usar un HD o un pendrive. Ojo, formateado en ext2 o ext3
5 - En el caso de usar un pendrive por ejemplo, crea una carpeta en el llamada por ejemplo XMLTV
6 - En el channels.map modifica la priemra linea indicando la carpeta que acabamos de crear para guardar alli los xml, en tu caso seria: XMLTV:www.xmltvepg.be/rytecxmltvportugal.gz:/DATA/usb1/sda1/XMLTV/rytecxmltvportugal
7 - lanza el epgKGD (/PLUGINS/PanelKGD/epg/./epgKGD)
8 - Pon el deco en standby
10 - espera en tu caso unos 15 minutos a que se cargue todo y luego comprueba.
7.257
1.396
El loadepg no podra trabajar si no te has descargado el xml previamente, el epgKGD te lo descarga cuando pones el deco en standby y luego lanza el loadepg para cargarlo en la memoria del AZbox.
