There are at least 3 ways of doing it.
One is with telesat's MutliCAS Edit and two others I will describe now:
MultiCAS/FW interaction
0) Home -> Plug-ins -> OpenXCAS -> no more Manual Install option, guys! It is now
DOWNLOAD EXECUTABLE -> you will see the links of support servers to get your plug-ins there, guys...
1) Downloaded and installed:
MultiCAS 16x... well, the latest - always!
2) In
Config - you will get the
configuration files for camd/CS SW, guys... In "Others" - nothing yet... From DOWNLOAD CONFIG one must
download MultiCAS CCcam config files.
3) So, off we go to Home -> Plug-ins -> [...] ->
MultiCAS ->
using your remote control -> Smart Card Splitter and CS.
4) Change the following, using your REMOTE:
-change the
Mode to
Client CCcam [if, like me, you have no smartcard to play with and share] - you can connect to other people's servers
-choose
Server No.
-choose
Host Name Use - write something like:
something.dyndns.org [whatever the data you get from your server/peer is, like gorski.dyndns.org or whatever your server is called like - I DO NOT HAVE A SERVER, THIS IS ONLY AN EXAMPLE!!!],
-choose the
Port - 12000 or
whatever it is that your peer tells you to use
-User Name - whatever it is [you must have a username that normally your peer gives you and put in his server to allow you access to his server]
-Password - whatever it is [like above]
-Server -
Enable
-Connect - test it [but only AFTER I enabled the one which appears below it, on the TV screen...]
It should say "
login success"...
Repeat for all the servers you have, up to 32, for now... Enough?
Red Button = Save.
5) But still: as soon as I wanted to get out,
it first asked me, in a little pop-up window, if I want to login to all my servers now. Press
OK, of course. It will connect to your Leete las normas aaaaaand....
...once in a TV channel, the connection was fast!!! Let's just leave it at that. Pink/Total TV [Irdeto/N*D*S]: vroom, vrooooommmm!!!
Well, I only have 3 servers but all was working just fine, loadsa stuff open, more-or-less stable...
Here is how to install it from a file you get on a forum like this one:
FileZilla -> into AZbox HD -> Plugins -> OpenXCAS -> MultiCAS ->
delete all "example" files, openxcas.conf and multicas emu_module.
Put in openxcas.conf and emu_module files from this post [attached].
Give emu_module CHMOD to 755.
Reboot.
The right version showing in AZbox HD. All servers should be preserved, if you put them in before!
Server details are in MultiCAS in /tmp file: ccc_serverstatus.info
The rest as above..:have a nice day:
I think it's a great idea that we can setup the CS part via remote entirely!!!! Makes it usable for many people!
