hola,debo decir que ahora he instalado un august dvb-t202 y tampoco me funciona,me pone esto en telnet
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 312888K/524288K available (7440K kernel code, 367K rwdata, 1436K rodata, 272K init, 137K bss, 211400K reserved, 0K cma-reserved)
Hierarchical RCU implementation.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 751 MHz (375.761 MHz counter)
Console: colour dummy device 80x25
Calibrating delay loop... 749.56 BogoMIPS (lpj=374784)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Initializing cgroup subsys memory
SMP: Booting CPU1...
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
CPU1 revision is: 0002a065 (Broadcom BMIPS4380)
FPU revision is: 00130001
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.20
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource wktmr
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
futex hash table entries: 512 (order: 3, 32768 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996
[email protected]).
fuse init (API version 7.23)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
console [ttyS0] disabled
serial8250.0: ttyS0 at MMIO 0x10406800 (irq = 62, base_baud = 5062500) is a 16550A
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0x10406840 (irq = 63, base_baud = 5062500) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406880 (irq = 64, base_baud = 5062500) is a 16550A
loop: module loaded
ahci ahci.0: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag clo slum part
scsi host0: ahci
scsi host1: ahci
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 87
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 87
brcmstb_nand: NAND controller driver is loaded
libphy: Fixed MDIO Bus: probed
__clk_enable: network [1]
__clk_enable: enet [1]
bcm7552_pm_genet_enable 00
bcmgenet bcmgenet.0: GENET 2.0 EPHY: 0x00b0
bcmgenet bcmgenet.0: failed to get enet-eee clock
libphy: bcmgenet MII bus: probed
bcmgenet bcmgenet.0: configuring instance for internal PHY
attached PHY at address 1
__clk_disable: enet [0]
bcm7552_pm_genet_disable 00
__clk_disable: network [0]
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
bcm7552_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 2
ohci-brcm ohci-brcm.0: irq 67, io mem 0x10480400
ata1: SATA link down (SStatus 0 SControl 300)
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
usbcore: registered new interface driver btusb
Driver 'mmcblk' needs updating - please use bus_type methods
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-brcmstb sdhci-brcmstb.0: Enabling controller
sdhci-brcmstb sdhci-brcmstb.0: No vmmc regulator found
sdhci-brcmstb sdhci-brcmstb.0: No vqmmc regulator found
mmc0: SDHCI controller on sdhci-brcmstb.0 [sdhci-brcmstb.0] using ADMA
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
NET: Registered protocol family 17
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
nand: device found, Manufacturer ID: 0x01, Chip ID: 0xda
nand: AMD/Spansion S34ML02G1
nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
Creating 3 MTD partitions on "brcmnand.0":
0x000000500000-0x000010000000 : "complete"
0x000000500000-0x000000b00000 : "kernel"
0x000000b00000-0x000010000000 : "rootfs"
ubi0: default fastmap pool size: 95
ubi0: default fastmap WL pool size: 25
ubi0: attaching mtd2
ata2: SATA link down (SStatus 0 SControl 300)
ubi0: attached by fastmap
ubi0: fastmap pool size: 95
ubi0: fastmap WL pool size: 25
ubi0: attached mtd2 (name "rootfs", size 245 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 1956, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 3/0, WL threshold: 4096, image sequence number: 1323202830
ubi0: available PEBs: 0, total reserved PEBs: 1956, PEBs reserved for bad PEB handling: 36
ubi0: background thread "ubi_bgt0d" started, PID 64
ALSA device list:
No soundcards found.
UBIFS: background thread "ubifs_bgt0_0" started, PID 65
usb 2-1: new full-speed USB device number 2 using ohci-brcm
UBIFS: recovery needed
usb 1-2: new high-speed USB device number 3 using ehci-brcm
hub 1-2:1.0: USB hub found
hub 1-2:1.0: 2 ports detected
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 241635328 bytes (230 MiB, 1903 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID C7705648-FBFE-4F76-9D55-536BD0E167C0, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:13.
devtmpfs: mounted
Freeing unused kernel memory: 272K (8090c000 - 80950000)
random: nonblocking pool is initialized
usb 1-2.1: new high-speed USB device number 4 using ehci-brcm
input: ITE Technologies, Inc. USB Deivce as /devices/platform/ehci-brcm.0/usb1/1-2/1-2.1/1-2.1:1.1/0003:048D:9006.0001/input/input0
hid-generic 0003:048D:9006.0001: input,hidraw0: USB HID v1.01 Keyboard [ITE Technologies, Inc. USB Deivce] on usb-ehci_hcd-2.1/input1
usbcore: registered new interface driver tpm
formuler3: module_layout: kernel tainted.
Disabling lock debugging due to kernel taint
input: dreambox remote control (native) as /devices/virtual/input/input1
input: dreambox advanced remote control (native) as /devices/virtual/input/input2
DVB: registering new adapter (dvb0)
platform dvb0.0: DVB: registering adapter 0 frontend 0 (DVB-S2)...
input: front panel as /devices/virtual/input/input3
SGI XFS with security attributes, realtime, no debug enabled
boxmodel: module license 'proprietary' taints kernel.
usb 1-2.1: dvb_usb_v2: 2nd usb_bulk_msg() failed=-79
dvb_usb_af9035: probe of 1-2.1:1.0 failed with error -79
usbcore: registered new interface driver dvb_usb_af9035
bcmgenet bcmgenet.0 eth0: Link is Down
bcmgenet bcmgenet.0 eth0: Link is Up - 100Mbps/Full - flow control off
NET: Registered protocol family 10
sh (563): drop_caches: 3
out of order segment: rcv_next AED7DC72 seq AED7E7C2 - AED7E9D6
sh (603): drop_caches: 3
ofo requeuing : rcv_next AED7E7C2 seq AED7E7C2 - AED7E9D6
usb 1-2.1: USB disconnect, device number 4
usb 1-2.1: new high-speed USB device number 5 using ehci-brcm
usb 1-2.1: dvb_usb_af9035: prechip_version=83 chip_version=02 chip_type=9135
usb 1-2.1: dvb_usb_v2: found a 'ITE 9135(9006) Generic' in cold state
usb 1-2.1: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
usb 1-2.1: dvb_usb_af9035: firmware version=3.39.1.0
usb 1-2.1: dvb_usb_v2: found a 'ITE 9135(9006) Generic' in warm state
usb 1-2.1: dvb_usb_af9035: [0] overriding tuner from 00 to 60
usb 1-2.1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (ITE 9135(9006) Generic)
af9033 7-0038: firmware version: LINK 3.39.1.0 - OFDM 3.9.1.0
af9033 7-0038: Afatech AF9033 successfully attached
usb 1-2.1: DVB: registering adapter 1 frontend 0 (Afatech AF9033 (DVB-T))...
input: ITE Technologies, Inc. USB Deivce as /devices/platform/ehci-brcm.0/usb1/1-2/1-2.1/1-2.1:1.1/0003:048D:9006.0002/input/input4
hid-generic 0003:048D:9006.0002: input,hidraw0: USB HID v1.01 Keyboard [ITE Technologies, Inc. USB Deivce] on usb-ehci_hcd-2.1/input1
