postado em openrsi porDarkSkies
Upgrading has never been so easy.
NOTE: This procedure is based on an installation on the DOM module and NOT on a USB stick.
And please, keep in mind: Use this at your own risk !!!
To upgrade:
First make sure the "Hardware acceleration" is DISABLED, this is very important !!!!
Make sure you have a internet connection, and please use a LAN network cable.
Then change in the settings menu the firmware download url to: http://www.openrsi.org
Click on OK and relax. Updating can take appr. 25 minutes.
After a successful installation, use the online update feature in OpenRSi. You can start this feature by pressing the blue button on your remote and selecting Software Management -> Software update.
Have fun !!!
http://youtu.be/qhzb2NOF1Dw
To upgrade:
Have fun !!!
