#!/bin/sh
# rcS Call all S??* scripts in /etc/rcS.d in
# numerical/alphabetical order.
# Version: @(#)/etc/init.d/rcS 2.76 19-Apr-1999 [email protected]
PATH=/sbin:/bin:/usr/sbin:/usr/bin
runlevel=S
prevlevel=N
umask 022
export PATH runlevel prevlevel
# Make sure proc is mounted
[ -d "/proc/1" ] || mount /proc
# See if system needs to be setup. This is ONLY meant to
# be used for the initial setup after a fresh installation!
if [ -x /sbin/unconfigured.sh ]
then
fi
# Source defaults.
. /etc/default/rcS
# Trap CTRL-C &c only in this shell so we can interrupt subprocesses.
trap ":" INT QUIT TSTP
# Do we have /proc/progress and set VERBOSE to "no" ?
# If so, calculate the number of scripts and the incremental step
# HACK: progress needs LCD to create /proc device entry
if [ -f /lib/modules/$(uname -r)/modules.dep ] && [ $(cat /lib/modules/$(uname -r)/modules.dep | grep dreambox_rc2 | wc -l) -gt 0 ]; then
/bin/true;
else
echo "regenerate module dependencies";
depmod -ae;
fi
[ $(cat /lib/modules/$(uname -r)/modules.dep | grep lcd | wc -l) -gt 0 ] && modprobe lcd
if [ "$VERBOSE" = no ]; then
if [ -e /proc/progress ]; then
set `ls -1 /etc/rc$runlevel.d/S* | wc`
numscripts=$1
# bootup, the first script, increments until 25.
# the userspace then picks up at 50
PROGRESS_incstep=`expr 25 / $1`
PROGRESS_value=25
PROGRESS=yes
export PROGRESS_value PROGRESS_incstep
fi
fi
export VERBOSE PROGRESS
# Call all parts in order.
for i in /etc/rcS.d/S??*
do
# Ignore dangling symlinks for now.
[ ! -f "$i" ] && continue
# Handle verbosity
[ "$VERBOSE" = very ] && echo "INIT: Running $i..."
if [ "$PROGRESS" = yes ]; then
export PROGRESS_value=`expr $PROGRESS_value + $PROGRESS_incstep`
echo "$PROGRESS_value Starting $i..." >/proc/progress
fi
case "$i" in
*.sh)
# Source shell script for speed.
trap - INT QUIT TSTP
set start
. $i
# No sh extension, so fork subprocess.
$i start
esac
# Report status based on result code
result=$?
if [ "$result" = 0 ]; then
echo "=s" >/proc/progress
else
echo "=f" >/proc/progress
fi
fi
done
# For compatibility, run the files in /etc/rc.boot too.
[ -d /etc/rc.boot ] && run-parts /etc/rc.boot
# Finish setup if needed. The comment above about
# /sbin/unconfigured.sh applies here as well!
if [ -x /sbin/setup.sh ]
then
/sbin/setup.sh
fi
swapon /media/hdd/swapfile
