Cool TV Guide
gorski
10 Abr 2009
1.334
9
Oh, the last version of CrossEPG, too... ;)
  • enigma2-plugin-systemplugins-crossepg_0.6.2-svn-300-r0_mipsel.rar
    767,8 KB · Visitas: 46
15.935
No sé que hago mal, pero no hay forma de que me salgan más de dos eventos con el firm 1.0.
Thanks Gorsky.
chiripa_kdt
22 Ene 2009
163
Podrias explicar como se instalan los picons y de donde pillarlos jejjeej,novato que es uno
Gtacias
tienes q crear una carpeta llamada picon en /usr/share/enigma2/ para q te quede asi /usr/share/enigma2/picon y dentro de esa carpeta metes los picon, los cuales encontraras en el apartado skins y picon
http://www.azboxhd.es/foro/index.php?app=core&module=attach&section=attach&attach_id=1261
estos son unos, hay varios modelos, prueba y deja los q mas te gusten
gorski
10 Abr 2009
1.334
9
If one has an original DOM [256MB only], one should use a USB memory stick in one's AZ!
On the USB [if it is initialised] one should create:
1) 256 MB SWAP file
2) picons folder - tens of MBs of little images [picons] would go there
3) direct CrossEPG to save its files there [XMLTV from Rytec etc.]
4) Damir subtitles plugin should also save its files here [various subs files]
Anything else?!?
If one has a larger DOM, say 1 or 4 GB one can do it all there...
If one has an HDD [built-in or USB one], one should still direct it all to a fast USB memory stick, NOT to a HDD...
One gets a more stable and faster machine... in theory... ;) B)
