cccam_prerelease_3_nds_fix
nasky
9.176
1.168
dveras dijo:
normal creo que no rula ninguna...
Te habras quedado agusto con esa afirmacion :redbullsmiley:
Muchos foreros la han usado y si que funciona, tiene errores porque son versiones alpha pero funcionar funciona
gorski
10 Abr 2009
1.334
9
Indeed, it works. With many bugs but it works. Not with NDS or Irdeto2, at least for me but Viaccess etc.
Let's hope they improve it properly... ;)
dveras
28 Abr 2009
913
30
admin dijo:
yo por mas que miro y remiro no me abre la suscripcion...
conecta con el server pero nada mas... no abre
os pego parte del log eliminando y alterando datos para no proporcionar demasiados datos...
tal vez lo hago yo mal pero es que con ninguna de las 3 betas he funcionado.
Si funciona con incubus pero se cuelga muy a menudo...
MMP[CCcamCAS]$ [00:17:29] [cccam_client] Starting cccam_client pre release v. 0.
1 for Azbox Elite/Premium receivers.
[00:17:29] [cccam_client] Coded by The_Ripper ;)
Thx to all who helped me ;)
[00:17:29] [cccam_client] Special Thanks goes to uvadi.
[OPENXCAS_API:Thu Jun 4 00:17:29.024] openxcas_open:285 ## CCcamCAS
[OPENXCAS_API:Thu Jun 4 00:17:29.029] load_xcas_control:98 ## loaded controller
ID = 0x19760507
osdep_msq_server_open : key_request 0x6C4B094 key_response 0x6C4B095
osdep_msq_server_open : request msq is already created
osdep_msq_server_open : response msq is already created
osdep_msq_client_connect : key_request 0x6C4B094 key_response 0x6C4B095
[00:17:29] [cccam_client] Creating cccam worker thread ...OK
[00:17:29] [cccam_client] Creating openxcas API message thread ...OK
[00:17:29] [cccam_client] Trying to connect to server (xxxxxxxxxxxxxxxxx)
[00:17:29]
[00:17:29] ReReading pmt.tmp
[00:17:29] ==================================================================
[00:17:29] ECM: CA ID: 0x1810 Nagravision -> CA PID: 0x0874
[00:17:29] ECM: CA ID: 0x0100 Seca/Mediaguard (4106) -> CA PID: 0x04B0
[00:17:29] [cccam_client] Connected to (xxxxxxxxxxxx) ...
[00:17:32] [cccam_client] Creating cccam worker thread for (xxxxxxxxxxxxxxxx
) ...OK
[00:17:56] Remove card : 0x0919_D8E80800
[00:17:57] Remove card : 0x1702_D8E80800
[00:18:05] Add card : 0x0919
[00:18:06] Add card : 0x1702
[00:18:26] [cccam_client] Closing connection for (xxxxxxxxxxxxx). Server
gone offline
[00:18:33] [cccam_client] Trying to connect to server (xxxxxxxxxxxxxxx)
[00:18:33] [cccam_client] Connected to (xxxxxxxxxxxxxxxxxx) ...
[00:18:38] [cccam_client] Creating cccam worker thread for (xxxxxxxxxxxxxxx
) ...OK
[00:18:55] Remove card : 0x0919_D8E80800
[00:18:56] Remove card : 0x1702_D8E80800
[00:18:56] Add card : 0x0919
[00:18:57] Add card : 0x1702
[00:19:14] Remove card : 0x0919_DAE80800
[00:19:15] Remove card : 0x1702_DBE80800
gorski
10 Abr 2009
1.334
9
Is this the same thing or?!? I hate it when there's nothing written, not even a minimal readme... Nuts!
* Yes same binary (checked with CRC) *
comtren
23 Feb 2009
66
¿alguien ha probado los canales HD?.
Un Saludo.
jblimon
13 Ene 2009
67
los españoles no me los abre, los alemanes por ejemplo, si. Con algun que otro cortecillo, pero algo mas estable si se ve. Y el zaping, pues unos 2 o 3 segundos hasta que abre...
dveras
28 Abr 2009
913
30
podrias indicar que permisos tienes puestos a los archivos? y si la línea C: es siguiendo el mismo formato que lo que viene dentro?
Porque no entiendo porque a muchos de vosotros se os ve y a mi no... dices que los alemanes si? voy a probar.
Es raro porque con incubus si abre los españoles.
fernando1964
26 Mar 2009
955
los españoles no se abren , aun , solo la generalista antena 3 , no se poque, a medida que vaya avanzando la beta se iran viendo cosas, no hay que apresurarse
jblimon
13 Ene 2009
67
los españoles se abren todos, menos los HD.
Para quien preguntaba los atributos:
En:
/camd/OpenXCAS
module.seq=755
openxcas.conf=755
En;
/camd/OpenXCAS/CCcamCAS
CCcam.cfg=644
cccam_module=755
openxcas.conf=755
tinos
26 Mar 2009
52
Los openxcas.conf y module.seq pueden ser 644 perfectamente. Sólo es necesario el cccam_module con 755.
Pues a mi no me abría nada del D+ en Astra (excepto MTV por algun otro proveedor). He de probar este nuevo pero sospecho no funcionara (es solo un fix para NDS)... hay algo que todavía no va fino, es una alpha (prerelease) que no llega a beta todavía. Para mi que esta bien para hacer pruebas pero la gente que quiera utilizarla mejor incubus 0.55 por ahora.
jromero
11 Ene 2009
1.102
jblimon dijo:
En:
/camd/OpenXCAS
module.seq=755
openxcas.conf=755
En;
CCcam.cfg=644
cccam_module=755
openxcas.conf=755
Cuando dices los españoles a que canales te refieres exactamente y otra cosa, es de astra o Hispasat??
dveras
28 Abr 2009
913
30
bueno, yo acabo de estar probado con franceces o alemanes y conecta con el server y cuando le envía la ECM el deco se queda ahi... no la recibe correctamente (luego espero y la envía bien) abre la suscripccion y al momento la vuelve a cerrar.
En el log desde telenet viendo la comunicación con el deco y server fallan los envíos de ECM, Voy a volver al incubus que parece que aguanta un poco mas (al menos horas sin colgarse) no minutos o segundos del ccccam, he puesto los permisos tal como figuran arriba.
jblimon
13 Ene 2009
67
jromero dijo:
me refiero a la plataforma española, todos menos los HD, hablo de Astra... no he probado por hispa. Pero eso si, el algunos son dos segundos y en otros hasta 15, osea que el zaping aun esta bastante mal.
Le estoy sirviendo con la 500s, la cual abre canales entre 1 y 2 segundos, osea que bien... pero al AZ no llega en condiciones.
madomape
14 Feb 2009
946
45
Probando esta nueva versión, me acabo de dar cuenta de que con el CCCam Pre3 si se abren los HD alemanes y con el Incubus no. Además, yo tampoco consigo ver los españoles por Astra a los que estoy abonado mientras que con el Incubus si. Seguiremos probando hasta que salga la versión definitiva.
dveras
28 Abr 2009
913
30
madomape dijo:
Hola, tienes algun corte o cuelgue del incubus visionando el digital por astra? es que a mí con incubus me pasa que cuando lleva rato rulando si no cambio mucho de canal se cuelga y sale el letrero de codificado.
madomape
14 Feb 2009
946
45
Sí, yo también tengo cortes después de un rato. De todas formas y aunque con otros proveedores se ve más con el CCC que con el Incubus, tengo que seguir con este último porque para los españoles, el CCC no funciona nada de nada en mi caso.
Mejor tener cortes que estar a oscuras.
fernando1964
26 Mar 2009
955
a mi me pasa lo mismo , probaremos las siguientes betas a ver qeu tal , o la definitiva
