Esto sale en el Puty:
Tango2 frequency scaling module installed.
NTFS driver 2.1.28 [Flags: R/W DEBUG].
JFFS2 version 2.2. © 2001-2006 Red Hat, Inc.
fuse init (API version 7.8)
SGI XFS with large block numbers, no debug enabled
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 9) is a 16550A
serial8250: ttyS1 at MMIO 0x0 (irq = 10) is a 16550A
loop: module loaded
nbd: registered device at major 43
tango2_enet: ethernet driver for SMP863x internal mac
tango2_enet: detected phy at address 0x01
tango2_enet: mac address 00:02:14:16:c2:bc
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ide0: SMP86xx Bus Mastering IDE controller
Probing IDE interface ide0...
hda: Memory Card Adapter, CFA DISK drive
hda: no 80 conductors cable, falling back to lower udma mode
hda: selected mode 0x42
hda: set to Ultra DMA mode 2
ide0: DMA enabled for ATA DISK hda
ide0 at 0x223c0-0x223c7,0x22398 on irq 26
hda: max request size: 128KiB
hda: 3913728 sectors (2003 MB) w/1KiB Cache, CHS=3882/16/63, UDMA(33)
hda: unknown partition table
QLogic Fibre Channel HBA Driver
physmap flash device CS2: 0x800000 at 0x48000000
CS2: Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Using physmap partition definition
Adding partition #1-#5
Creating 5 MTD partitions on "CS2: Physically mapped flash":
0x00000000-0x00020000 : "CS2-Part1"
0x00020000-0x00040000 : "CS2-Part2"
0x00040000-0x00080000 : "CS2-Part3"
0x00080000-0x00700000 : "CS2-Part4"
0x00700000-0x00800000 : "CS2-Part5"
PCI: Enabling device 0000:00:02.2 (0000 -> 0002)
ehci_hcd 0000:00:02.2: EHCI Host Controller
ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.2: irq 22, io mem 0x62008000
ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
driver tangox-ehci-hcd, 10 Dec 2004
TangoX USB initializing...
tangox-ehci-hcd tangox-ehci-hcd: TangoX USB 2.0
tangox-ehci-hcd tangox-ehci-hcd: new USB bus registered, assigned bus number 2
tangox-ehci-hcd tangox-ehci-hcd: irq 48, io mem 0xa0021400
tangox-ehci-hcd tangox-ehci-hcd: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
TCP cubic registered
NET: Registered protocol family 1
NET: Registered protocol family 17
Waiting 12sec before mounting root device...
VFS: Cannot open root device "hda1" or unknown-block(3,1)
Please append a correct "root=" boot option; here are the available partitions:
0300 1956864 hda driver: ide-disk
1f00 8192 mtdblock0 (driver?)
1f01 128 mtdblock1 (driver?)
1f02 128 mtdblock2 (driver?)
1f03 256 mtdblock3 (driver?)
1f04 6656 mtdblock4 (driver?)
1f05 1024 mtdblock5 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs
loop: module loaded
