Actualizado NCam+ a la version 11.3_r2 (ya disponible en Descargas Openspa desde vuestros decos).
Lo nuevo:
- Add cx-aio-v09.2.6 pacth. (
Agradecer la gran ayuda de @darkmantk para la adaptacion del parche a NCam).
- Rework code ref gbox_maxecmsend.
- Fix sharing instability side effect.
- [powervu] Fixed emm algo.
- Fixed warning messages with high GCC 9.x.x
- Fixed warning integer constant is too large for long type.
- Add Newcamd NCam and MGcamd (Stealth mode)
- Fixed gbox module ecm debug string error.
- Add repeat to ask all gbox readers again during fallback time.
- Fixed for CAK7 Cards HD03/04/05.
-Updated: Multics detection
(added to the detected multics, protocol = mgcamd_mcs or newcamd_mcs,
removed: protocol = cccam_mcs_HB and Multics client detection (does not send unique IDs in client mode))
-fix camd35/ext mode
-webif cache-size / reader page for lg-flagged CWs
-Add camd BISS2 (Beta Test)
-repeat to ask all gbox readers again during fallback time (Thank's chimpie232)
-Add support powervu for android device ## New feature
-Add wi_socket_id option ## New option
-Add repetitions_forced option to enable/disable CCcam.cfg work ## New option
-Correction some codes
-Some cusomize for MgCamd
-Skip CWs checksum update
Agradecer tambien la ayuda en los test de los compañeros @lobosnake y @elduque.
CONSEJO!!!: Antes de instalar cuanquiera de los OScam o NCam+ del panel descargas, es mas que recomendable parar la Cam en uso en el CamdManager.
Salu2
