- 31 Ene 2009
- 55
- 14
Buenas he encontrado esto que me parece muy interesante:
Duo2 VFD Controller Update
Since VFD in Duo2(Serial NO. : D06227XXXXX, D06326XXXXX)
has interference with IR sensor, VFD controller needs to be updated.
To update VFD controller, first install the latest image on code.vuplus.com.
By "Firmware Upgrade" plugin, you can upgrade VFD controller.
If you don't have internet connection in your Duo2, first download(Save Link As) duo2.bin.vfd and duo2.bin.vfd.md5.
Transfer those two files to the box. Or insert USB memory containing files to the box.
And follow the procedure on
HowTo Offline Update.
If you can connect internet in your Duo2, refer to
HowTO Online Update.
NOTE) This update is optional. If you have no problem in remote control, update is not necessary.
