Vplug 2.2.0
txutxy
22 Mar 2007
254
- Fixed S*x Vi*w I2 AU
Notes:
Here is the new vPlug’s I2 flowers schema (to stop releasing new versions just because of the master key changes) :
I CAID_ProviderId key_index flower ; op-key (clear or encrypted)
I CAID_ProviderId M0 flower; EMM-Seed (clear)
I CAID_ProviderId M1 flower; ECM-Seed (clear)
I CAID_ProviderId M2 flower; Common-IV (clear ecm & emm IV’s)
I CAID_ProviderId M3 flower; Clear-PMK0
I CAID_ProviderId M4 flower; Clear-PMK1
I CAID_ProviderId M5 flower; Encrypted-PMK0
I CAID_ProviderId M6 flower; Encrypted-PMK1
I CAID_ProviderId M7 data; Clear-SA
I CAID_ProviderId M8 data; Encrypted-SA
I CAID_ProviderId M9 data; Clear 3 byte EMM header eg. 82703F or 82403F or …
I CAID_ProviderId F0 IsEncrypted; To use encrypted data, set IsEncrypted to 01 (otherwise 00)
Don’t worry about the above info, I2-flowers.txt file has been included… (don’t forget to import that file, otherwise nothing would work for you, click here to view the how to)
Uploado :flowers2:
ichimr285
No presentado al foro
24 Oct 2008
Do you like cosplay Do you know which game character is it
See the answer click here. Want to see more cosplayer ? [size=10pt]Recommend : [/size][size=10pt]D.Gray-Man Lavi World of warcraft [/size][size=10pt]Ragnarok Online cosplay [/size]
