Tuner no llega a mostrar imagen
neo_jank
24 Ago 2020
Hola a todos,
Tengo un VU+ Uno 4K SE que, hasta ayer, funcionaba correctamente, era capaz de mostrar imagen sin problema.
Hoy, aunque recibe señal, Porque las barras de S y Q en el canal están en 76%/96%, no es capaz de mostrar imagen. Obviamente, estoy mirando canales en abierto :)
El LNB a priori no está estropeado, porque mi vecino es capaz de recibir la señal correctamente.
Mirando los logs de debug, comenta algo de que no transponder tuned. A alguien se le ocurre que puede estar pasando?
12:51:48.4175 [ ] base/huffman.cpp:27 huffman_read_dictionary [huffman] read.. '/usr/share/enigma2/otv_00c00000_0001_0410.dict'
12:51:48.4176 [ ] dvb/epgcache.cpp:1831 startEPG [eEPGCache] abort non avail OpenTV EIT reading
12:51:48.4176 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=57
12:51:50.4164 [ ] dvb/demux.cpp:88 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux0
12:51:50.4165 [ ] dvb/demux.cpp:284 start [eDVBSectionReader] DMX_SET_FILTER pid=17
12:51:55.4512 [ ] dvb/epgcache.cpp:2241 abortNonAvail [eEPGCache] abort non avail nownext reading
12:51:55.4521 [ ] dvb/epgcache.cpp:2248 abortNonAvail [eEPGCache] abort non avail schedule reading
12:51:55.4525 [ ] dvb/epgcache.cpp:2255 abortNonAvail [eEPGCache] abort non avail schedule other reading
12:51:55.4526 [ ] dvb/epgcache.cpp:2279 abortNonAvail [eEPGCache] abort non avail netmed schedule reading
12:51:55.4531 [ ] dvb/epgcache.cpp:2286 abortNonAvail [eEPGCache] abort non avail netmed schedule other reading
12:51:55.4532 [ ] dvb/epgcache.cpp:2295 abortNonAvail [eEPGCache] abort non avail FreeSat schedule_other reading
12:51:55.4534 [ ] dvb/epgcache.cpp:2306 abortNonAvail [eEPGCache] abort non avail viasat reading
12:51:55.4536 [ ] dvb/epgcache.cpp:2314 abortNonAvail [eEPGCache] abort non avail mhw reading
12:52:06.4052 [ ] dvb/pmt.cpp:215 PATready [eDVBServicePMTHandler] PATready
12:52:06.4053 [ E ] service/servicedvb.cpp:1207 serviceEvent [eDVBServicePlay] DVB service failed to tune - error 2
12:52:22.4042 [ ] dvb/dvbtime.cpp:425 updateTime [eDVBLocalTimerHandler] no transponder tuned... or no TDT/TOT avail .. try to use RTC :)
12:52:22.4639 [ ] dvb/dvbtime.cpp:434 updateTime [eDVBLocalTimerHandler] RTC time is 12:52:21
12:52:22.4639 [ ] dvb/dvbtime.cpp:440 updateTime [eDVBLocalTimerHandler] Receiver time is 12:52:22
12:52:22.4639 [ ] dvb/dvbtime.cpp:442 updateTime [eDVBLocalTimerHandler] RTC to Receiver time difference is 1 seconds
12:52:22.4639 [ ] dvb/dvbtime.cpp:445 updateTime [eDVBLocalTimerHandler] set Linux Time to RTC Time
12:52:21.4641 [ ] dvb/dvb.cpp:2420 getDemux [eDVBChannel] getDemux cap=00
12:52:50.4116 [!W!] dvb/scan.cpp:1204 channelDone [eDVBScan] the current channel's ID was not corrected - not adding channel.
12:52:50.4116 [ ] dvb/pmt.cpp:1010 SDTScanEvent [eDVBServicePMTHandler] ignore sdt update data.... incorrect transponder tuned!!!
12:52:50.4117 [ ] dvb/pmt.cpp:1012 SDTScanEvent [eDVBServicePMTHandler] incorrect namespace. expected: c00000 current: ffffffff
12:52:50.4117 [ ] dvb/pmt.cpp:1014 SDTScanEvent [eDVBServicePMTHandler] incorrect transport_stream_id. expected: 410 current: ffffffff
12:52:50.4118 [ ] dvb/pmt.cpp:1016 SDTScanEvent [eDVBServicePMTHandler] incorrect original_network_id. expected: 1 current: ffffffff
