- 19 Mar 2007
- 11.803
- 596
Diagrama de Funcionamiento
The First Wireless HDMI Extender featuring Cable-Free High Definition Extension up to 30 Feet.
The Wireless HDMI Extender delivers a plug and play method of extending audio/video wirelessly up to 10 meters (33 feet) in distance, with a perfect replication of high definition visuals up to 1080p at 30 fps, or 1080i at 60 fps, and full digital and analog audio support for connecting HDTV sources, such as satellite set top boxes, HD DVD players and gaming systems. All IR signals are
also transmitted from the receiver back to the sender for total control.
How it works
Connect your two HDMI video sources and your one component video source to the Wireless for HDMI transmitter. Then connect the IR blaster to your sources using the supplied blaster cable. Then connect the Wireless for HDMI receiver unit to your HDMI or DVI display. Source switching is done via the included RMT3-IR or by using the autoswitch feature will allow you to switch when a new source is turn on.
Package Includes:
* Wireless HDMI Extender
* One 6 ft HDMI Cable
* IR Blaster Cable
* RMT3-IR
* Two 5V Power Supplies
* User's Manual
Features:
* Guaranteed bandwidth reservation: Full Quality of Service (QoS) based on WiMedia Alliance MAC specification
* Real-time, visually lossless HD compression
* Two channel and multi-channel compressed PCM @ 32KHz, 44.1KHz, and 48KHz
* High error resiliency: Wavelet transform provides high-quality image under varying channel conditions
* Dynamic bit rate adjustment: Predictable, on-the-fly control of channel bandwidth consumption
* Fully compliant family of HDMI/HDCP products
* Fully DVI compliant
* Two HDMI inputs
* Analog audio input
* Component video input
* IR Blaster jack
* Input selection button
Specifications:
* Up to 30 feet line-of-sight wireless operation with 65 Mbps throughput
* Frequency band: : 3.1 - 4.8 GHz
* Resolution support : 480i, 480p, 720p, and 1080i
* HDMI v1.2a: Compliant and interoperable
* Consumer Electronics Control (CEC)
* Tzero RF Radio Chipset
* ADI JPEG 2000 visual lossless compression
* Power Supply: 5V DC
* Power Consumption: 20 watts (max)
* Operating temperature 0 to 70 celcius
* Shipping Weight: 6 lbs.
Link para mas información
http://www.gefen.com/kvm/product.jsp?prod_id=4318
