- 27 Ago 2009
- 73
We know and saved all winamp streamripper to the wonderful tool to keep the tracks while listening to the same ready-made as mp3 files. Here we have the streamripper for azbox. Listening to music does not work yet properly locked so the appropriate tab. But the most important works, the ribs.
Now, one can therefore follow the TV comfortably, while increased in the background, the mp3 collection of songs from his favorite station.
Among the settings in the tab 'Config' need probably say nothing, it's all so similar to the Windows version. The important thing is the path to the directory to be stored in the. The best place in the streamrip.cfg his own path as the first, then you need not scroll to the plugin. The other options can I try each in order to obtain optimal results. The genres can also set each of themselves and adding streamrip.cfg in. To each channel a few names and id to do so. The raussuchen must be on the side of shoutcast. It is simply too exhausting to programmatically read the data directly from the site. Such sites are overloaded with too much stuff and every day can totally change the structure.
At the moment it is set up in the program so that stops when you reach the download volume (stop ripping after) the streamripper its activities. The value at the beginning to 10 MB and can be increased to 500 MB.
With the blue function key i-KEY is the riders 'Ripper'. Here you should select with the arrow keys left / right from the genre, then it goes up with the arrow keys / down to a station. Well OK button and wait about 2 seconds until the matter is ongoing. Up in the status area, you watch the current title. Then you can exit with the exit button, the plug and turn to other things.
Later, you can call the plugin again to finish the ribs, possibly prematurely. In addition to the tab 'ripper' switch down to 'stop ripping' and OK button.
The plugin is really just an interface for controlling streamripper with the remote control, because who wants to enter a yard long and cryptic lines. Through the installation requires about 250 kB
The program is not fully tested, because there are simply too many possibilities, but as azbox we have seen happen.
Concerning information on problems or mistakes, I am very grateful. Use at your own risk!
Also!!!
internet radio show with images (CD cover, or other relevant image for the song) and streamripper in a plugin
Prerequisite: firmware with resolution of 960x540 mode in the plug on the box (0.9.3877 is ok), or may not be all things visible, and of course a working broadband Internet connection
The plugin is not the usual keyboard queries used, maybe once a person is so friendly with a premium Azbox and try it out, because I can test it only with my Azbox elite, as it is of course perfectly.
automatic resumption of music after buffering
Image downloads in plugingesteuertem separate program
With a few word this program has internet music radios(like shoutcast radios) and you can rip their streams to mp3
Also!!!
