hola a todos aver si alguien me puede ayudar en eso
tengo una card n*s videoguard cuando la corro por telnet me da ese caid5786 y los caid son esos caid0905/0945 aqui les dejo un logo aver que me sugieran saludos y gracias por favor ayudenme..
06:16:43 sbox: Viewing Pay TV without a valid subscription is illegal
06:16:43
06:16:43 Wellcome to SBox (for PowerPC)
06:16:43 Version: 0.0.4-8 (16/12/2010 #2)
06:16:43 WebPage: http://www.sboxobs.tk
06:16:43
06:16:43 sbox: checking for /var/bin/sbox.conf... OK
06:16:43 io: sci device detected
root@dreambox:~>
06:16:44 reset: got atr on slot0
06:16:44 reset: atr 3FFF13250250800F54B003FFFF4A508000000000545605
06:16:44 reset: hist 54B003FFFF4A508000000000545605
06:16:44 reset: char T J P T V
06:16:44 reset: working at 3.570Mhz (max 5.000Mhz)
06:16:44 sbox: n*s card init
06:16:57 n*s: serial 4023XXX(107609XXX)
06:16:57 n*s: provider 00, id 000000, ppua 57E22EF7, caid 5786
06:16:57 n*s: provider 01, id 000000, ppua 55292306, caid 5786
06:16:57 n*s: card init ok
06:16:57
06:17:01 newcamd: user=edk, pass=edk, au=0 added to db=0
06:17:01 newcamd: user=pe7676, pass=peppe, au=0 added to db=0
06:17:01 newcamd: user=CCcam, pass=CCcam, au=1 added to db=0
06:17:01 newcamd: server 10000 init ok
06:17:01 sbox: entering main loop
06:17:01 sbox: mixed mode
06:17:01 radegast: server 15000 init ok
06:17:01 webif: server started on port 8181, user=admin, pass=edk
06:17:02 stream 0: re-reading pmt.tmp (sid 0x0008)
06:17:02 stream 0: ecmpid 0x0905, caid 0x0945, prov 0x000000, system N**
06:17:02 stream 0: ecmpid 0x051D, caid 0x095B, prov 0x000000, system N**
06:17:02 stream 0: ecmpid 0x051D, caid 0x0905, prov 0x000000, system N**
06:18:44 stream 0: re-reading pmt.tmp (sid 0x0060)
06:18:44 stream 0: ecmpid 0x0907, caid 0x0945, prov 0x000000, system NDS
06:18:44 stream 0: ecmpid 0x051F, caid 0x095B, prov 0x000000, system NDS
06:18:44 stream 0: ecmpid 0x051F, caid 0x0905, prov 0x000000, system NDS
06:16:43
06:16:43
root@dreambox:~>
06:16:57
