Problema
aaom
AZmod
23 Feb 2009
1.895
26
No se que he cambiado tras instalar ultima beta del FW. La cuestion es que conecto con mis Leete las normas pero no abro ningun canal.
Creo que estoy ya cegato. Seguro que es una estupidez pero no lo veo. ¿Que puede ser?
[04:14:51] Searching CW cache for CaID 0x1810, pid 0x096A...no CW in cache
[04:14:51] <-|ECM ([DMX - 0]) (<-2) from XXXXXXXXXXXXXXXXXXX.org, caid:0x1810, ecmpid:0x096A, sidpid:0x0010, detected our boxid , trying local decode ...
[04:14:51] [NEWCAMD] Putting ECM ([DMX - 0]) (<-2) from XXXXXXXXXXXXXXXXXX.org, caid:0x1810, ecmpid:0x096A,sidpid:0x0010 in ECM buffer (1/10)
[04:14:51] [NEWCAMD] Sending ECM caid:0x1810, ecmpid:0x096A, sidpid:0x0010 to (localhost:20001).
[04:14:51] [NEWCAMD]-> OK
[04:14:51] <-|ECM ([DMX - 0]) (<-2) from XXXXXXXXXXXXXXXXXXXXXX.org, caid:0x1810, ecmpid:0x096A, sidpid:0x0010, for NETWORK PEER (3D63), trying to find ...
[04:14:51] [NETWORK]-> NOT OK,we cant reshare, peer maybe gone offline/lost card ? ...
[04:14:51] Searching CW cache for CaID 0x1810, pid 0x0867...same ECM allready in cache from XXXXXXXXXXXXXXXXXX.org
[04:14:51] <-|ECM ([DMX - 0]) (<-2) from XXXXXXXXXXXXXXXXXXXXXX.org, caid:0x1810, ecmpid:0x0867, sidpid:0x7500, detected our boxid , trying local decode ...
[04:14:51] [ECM]-> NOT OK,we cant decrypt, ignoring ...
[04:14:51] [NEWCAMD] sent sequence id 000B , received sequence id 000B
Mi Mbox.cfg
D: { 0 }
B: { 0 0 0 }
Z: { 11 01 }{ 192.168.0.192 8023 }
L: { 1 }
T: { /tmp/ }
K: { /PLUGINS/OpenXCAS/MboxCAS/ }
M: { 1 }
P: { /tmp/pmt.tmp }
W: { 0 }
Q: { 300 }
J: { 0 }
#V: { 7 11 3571200 0 0 0 0 0 }
Mi Cwshare:
M: { xxxx.dyndns.tv { xxxxxxxx }}
I: { 2 }
O: { 3000 2000 }
N: { 400 200 }
# aqui las lineas G
# aqui chiste
He probado con X+ y sin X+
Salud.os
Seku
Unsuario
29 May 2009
392
56
edita una linea que te ha quedado en el .log
crackmaximo
21 Jun 2009
A mi me pasa lo mismo cuando paso de cierto numero de Leete las normas.
Si lo solucionas por favor dime lo que es.
aaom
AZmod
23 Feb 2009
1.895
26
Seku_ dijo:
Ya esta. Muchas gracias no me di cuenta.
Bueno pues se ha resuelto reiniciando el Router. NO me pregunteis mas, solo digo lo que me ha pasado.
Salud.os
aaom
AZmod
23 Feb 2009
1.895
26
De nuevo no va.... tengo casi todos los Leete las normas ON pero no engancha con nadie.
aaom
AZmod
23 Feb 2009
1.895
26
Pues no se que leches es, pero algo se queda pillado. De nuevo reinicio deco + router y tema resuelto.
16.771
¿No será problema del dyndns?
aaom
AZmod
23 Feb 2009
1.895
26
Lo habia pensado pero hace mucho que actualizao 'a mano' asi que eso no creo que sea.
you can
16 Sep 2009
87
Buenas, intenta meterla cuenta en el router y mira si se te corta. Otra cosa paisano, algunos de la capi tambien tuvieron problemas con internet ultimamente con supercavel.
you can
16 Sep 2009
87
Se me olvidava, hace unos dias cambie el firm y me funcionaba fatal con mbox 6.10. He vuelto a la ultima version oficial y...ok. No se si sera por eso pero vamos, me funciona muy bien el 6.10, creo que es la primera vez.. De todas formas, dame un toque ppor mesenger si quieres.
