Muy buenas a tod@s,
Tengo una local de nuestro proveedor por Astra, y todos los dias se me cuelga por lo menos 1 vez.
Me conecto con mbox 0.5 0018 y este es el log del newcs cuando se bloquea, por si a alguien se le ocurre algo:
el archivo de configuracion de newcs.xml es este:
Sabeis si estoy haciendo algo mal??
Muchas gracias a tod@s
[ 11:12:22 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:12:22 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:12:22 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:12:24 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:12:24 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:24 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:12:24 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:24 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:12:24 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:12:24 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:12:26 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:26 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:26 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:12:26 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:12:26 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:12:28 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:12:28 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:28 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:12:32 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:12:32 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:32 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:32 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:32 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:12:32 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:12:32 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:12:33 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:33 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:33 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:12:33 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:12:33 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:12:34 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:12:34 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:34 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:12:34 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:12:34 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:12:35 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:12:35 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:36 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:12:36 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:39 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:12:39 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:39 ] [ SID ] Checking for SID 7694 for Reader 0 (upper) - SO is: 0
[ 11:12:39 ] [ Newcamd:20010 ] Accepted SID 7694 on Reader 0 (upper) from diego
[ 11:12:39 ] [ Card queue /dev/scard ] ECM added, sid 7694, prio 0
[ 11:12:40 ] [ Card queue /dev/scard ] ECM sid 7505, prio 0 too old!
[ 11:12:40 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:40 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:12:40 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:40 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:12:40 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:12:40 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:12:43 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:12:43 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:43 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:12:43 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:43 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:12:43 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:12:43 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:12:45 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:12:45 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:45 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:12:45 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:45 ] [ SID ] Checking for SID 77C6 for Reader 0 (upper) - SO is: 0
[ 11:12:45 ] [ Newcamd:20010 ] Accepted SID 77C6 on Reader 0 (upper) from diego
[ 11:12:45 ] [ Card queue /dev/scard ] ECM added, sid 77C6, prio 0
[ 11:12:45 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:45 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:12:45 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:12:45 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:12:47 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:12:47 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:50 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:50 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:50 ] [ SID ] Checking for SID 7694 for Reader 0 (upper) - SO is: 0
[ 11:12:50 ] [ Newcamd:20010 ] Accepted SID 7694 on Reader 0 (upper) from diego
[ 11:12:50 ] [ Card queue /dev/scard ] ECM added, sid 7694, prio 0
[ 11:12:51 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:51 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:51 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:12:51 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:12:51 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:12:53 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:12:53 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:54 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:12:54 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:54 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:12:54 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:12:54 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:12:54 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:12:54 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:55 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:12:55 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:12:55 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:55 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:55 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:12:55 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:12:55 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:12:57 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:12:57 ] [ Newcamd:20010 ] ECM <- diego
[ 11:12:57 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:12:57 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:12:57 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:13:00 ] [ Card queue /dev/scard ] ECM sid 7694, prio 0 too old!
[ 11:13:00 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:01 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:13:01 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:02 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:02 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:02 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:13:02 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:13:02 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:13:03 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:03 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:03 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:13:03 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:13:03 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:13:04 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:13:04 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:05 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:05 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:05 ] [ SID ] Checking for SID 77C6 for Reader 0 (upper) - SO is: 0
[ 11:13:05 ] [ Newcamd:20010 ] Accepted SID 77C6 on Reader 0 (upper) from diego
[ 11:13:05 ] [ Card queue /dev/scard ] ECM added, sid 77C6, prio 0
[ 11:13:05 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:05 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:13:05 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:13:05 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:13:06 ] [ Card queue /dev/scard ] ECM sid 77C6, prio 0 too old!
[ 11:13:06 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:06 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:13:10 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:10 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:10 ] [ SID ] Checking for SID 7504 for Reader 0 (upper) - SO is: 0
[ 11:13:10 ] [ Newcamd:20010 ] Accepted SID 7504 on Reader 0 (upper) from diego
[ 11:13:10 ] [ Card queue /dev/scard ] ECM added, sid 7504, prio 0
[ 11:13:11 ] [ Card queue /dev/scard ] ECM sid 7694, prio 0 too old!
[ 11:13:11 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:11 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:11 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:11 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:13:11 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:13:11 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:13:12 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:13:12 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:13 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:13 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:13 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:13:13 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:13:13 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:13:15 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:13:15 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:15 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:15 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:15 ] [ SID ] Checking for SID 77C2 for Reader 0 (upper) - SO is: 0
[ 11:13:15 ] [ Newcamd:20010 ] Accepted SID 77C2 on Reader 0 (upper) from diego
[ 11:13:15 ] [ Card queue /dev/scard ] ECM added, sid 77C2, prio 0
[ 11:13:16 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:13:16 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:16 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:16 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:16 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:13:16 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:13:16 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:13:18 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:13:18 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:20 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:20 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:20 ] [ SID ] Checking for SID 77C6 for Reader 0 (upper) - SO is: 0
[ 11:13:20 ] [ Newcamd:20010 ] Accepted SID 77C6 on Reader 0 (upper) from diego
[ 11:13:20 ] [ Card queue /dev/scard ] ECM added, sid 77C6, prio 0
[ 11:13:21 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:21 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:21 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:13:21 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:13:21 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:13:23 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:13:23 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:24 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:13:24 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:25 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:25 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:25 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:13:25 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:13:25 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:13:26 ] [ Card queue /dev/scard ] ECM sid 77C6, prio 0 too old!
[ 11:13:26 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:26 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:13:30 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:30 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:30 ] [ SID ] Checking for SID 77C6 for Reader 0 (upper) - SO is: 0
[ 11:13:30 ] [ Newcamd:20010 ] Accepted SID 77C6 on Reader 0 (upper) from diego
[ 11:13:30 ] [ Card queue /dev/scard ] ECM added, sid 77C6, prio 0
[ 11:13:31 ] [ Card queue /dev/scard ] ECM sid 7504, prio 0 too old!
[ 11:13:31 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:32 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:13:32 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:34 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:13:34 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:35 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:35 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:35 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:13:35 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:13:35 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:13:36 ] [ Card queue /dev/scard ] ECM sid 77C2, prio 0 too old!
[ 11:13:36 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:37 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:13:37 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:37 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:37 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:37 ] [ SID ] Checking for SID 0000 for Reader 0 (upper) - SO is: 0
[ 11:13:37 ] [ Newcamd:20010 ] Accepted SID 0000 on Reader 0 (upper) from diego
[ 11:13:37 ] [ Card queue /dev/scard ] ECM added, sid 0, prio 0
[ 11:13:38 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:38 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:38 ] [ SID ] Checking for SID 76CC for Reader 0 (upper) - SO is: 0
[ 11:13:38 ] [ Newcamd:20010 ] Accepted SID 76CC on Reader 0 (upper) from diego
[ 11:13:38 ] [ Card queue /dev/scard ] ECM added, sid 76CC, prio 0
[ 11:13:39 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:39 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:39 ] [ SID ] Checking for SID 7503 for Reader 0 (upper) - SO is: 0
[ 11:13:39 ] [ Newcamd:20010 ] Accepted SID 7503 on Reader 0 (upper) from diego
[ 11:13:39 ] [ Card queue /dev/scard ] ECM added, sid 7503, prio 0
[ 11:13:39 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:40 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:40 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:40 ] [ SID ] Checking for SID 0000 for Reader 0 (upper) - SO is: 0
[ 11:13:40 ] [ Newcamd:20010 ] Accepted SID 0000 on Reader 0 (upper) from diego
[ 11:13:40 ] [ Card queue /dev/scard ] ECM added, sid 0, prio 0
[ 11:13:41 ] [ Card queue /dev/scard ] ECM sid 77C6, prio 0 too old!
[ 11:13:41 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:41 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:13:41 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:41 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:13:41 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:13:41 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:13:42 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:13:42 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:44 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:44 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:44 ] [ SID ] Checking for SID 76C0 for Reader 0 (upper) - SO is: 0
[ 11:13:44 ] [ Newcamd:20010 ] Accepted SID 76C0 on Reader 0 (upper) from diego
[ 11:13:44 ] [ Card queue /dev/scard ] ECM added, sid 76C0, prio 0
[ 11:13:46 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:13:46 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:51 ] [ Card queue /dev/scard ] ECM sid 77C6, prio 0 too old!
[ 11:13:51 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:54 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:13:54 ] [ Newcamd:20010 ] ECM <- diego
[ 11:13:54 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:13:54 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:13:54 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:13:56 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:13:56 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:58 ] [ Card queue /dev/scard ] ECM sid 0, prio 0 too old!
[ 11:13:58 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:13:59 ] [ Card queue /dev/scard ] ECM sid 76CC, prio 0 too old!
[ 11:13:59 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:14:00 ] [ Card queue /dev/scard ] ECM sid 7503, prio 0 too old!
[ 11:14:00 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:14:01 ] [ Card queue /dev/scard ] ECM sid 0, prio 0 too old!
[ 11:14:01 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:14:01 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:14:01 ] [ Newcamd:20010 ] ECM <- diego
[ 11:14:01 ] [ SID ] Checking for SID 0000 for Reader 0 (upper) - SO is: 0
[ 11:14:01 ] [ Newcamd:20010 ] Accepted SID 0000 on Reader 0 (upper) from diego
[ 11:14:01 ] [ Card queue /dev/scard ] ECM added, sid 0, prio 0
[ 11:14:02 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:14:02 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:14:03 ] [ Newcamd:20010 ] Command 80 from diego len 100
[ 11:14:03 ] [ Newcamd:20010 ] ECM <- diego
[ 11:14:03 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:14:03 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:14:03 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:14:05 ] [ Card queue /dev/scard ] ECM sid 76C0, prio 0 too old!
[ 11:14:05 ] [ Newcamd ] ECM -> diego (NOT OK)
[ 11:14:10 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:14:10 ] [ Newcamd:20010 ] ECM <- diego
[ 11:14:10 ] [ SID ] Checking for SID 0000 for Reader 0 (upper) - SO is: 0
[ 11:14:10 ] [ Newcamd:20010 ] Accepted SID 0000 on Reader 0 (upper) from diego
[ 11:14:10 ] [ Card queue /dev/scard ] ECM added, sid 0, prio 0
[ 11:14:14 ] [ Newcamd:20010 ] Command 81 from diego len 100
[ 11:14:14 ] [ Newcamd:20010 ] ECM <- diego
[ 11:14:14 ] [ SID ] Checking for SID 7790 for Reader 0 (upper) - SO is: 0
[ 11:14:14 ] [ Newcamd:20010 ] Accepted SID 7790 on Reader 0 (upper) from diego
[ 11:14:14 ] [ Card queue /dev/scard ] ECM added, sid 7790, prio 0
[ 11:14:15 ] [ Card queue /dev/scard ] ECM sid 7790, prio 0 too old!
[ 11:14:15 ] [ Newcamd ] ECM -> diego (NOT OK)
<?xml version="1.0"?>
<newCSconfig>
<readers name="Card Readers">
<device>
<name>upper</name>
<type>azbox</type>
<node>/dev/scard</node>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>no</blocksa>
<blockua>no</blockua>
<blockga>no</blockga>
<boxid></boxid>
<PTShandshake>no</PTShandshake>
<Seca-PPV>no</Seca-PPV>
<crypto-special>no</crypto-special>
<carddetect>yes</carddetect>
<newcamd_port>20010</newcamd_port>
<autosid>no</autosid>
<priority>fifo</priority>
<mhz>368</mhz>
</device>
</readers>
<xmlserver>
<enabled>0</enabled>
</xmlserver>
<radegastserver>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<debug>
<darint39>sintoi51</darint39>
<level>internal</level>
<type>all</type>
<output>console,tcp</output>
<logfile>/tmp/newcs.txt</logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host>172.16.1.1</udp_host>
<udp_port>9000</udp_port>
<udp_options></udp_options>
<tcp_port>1001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>local</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>diego</name>
<password>0000ff</password>
<au>on</au>
</user>
</newcamd_server>
</newCSconfig>
