Problem with recording
Akura
25 Jun 2011
Hi,
After few days of tests, this firmware is very stable, great job guys.
But I have a little problem with the recording :
When reading the image is black. I must zap to a FTA (free to air) channel before starting to read to recover the image. it looks like cccam still influences on reading... It's the same problem for the sound. If I'm on a channel with AC3 and and want to read a recording with no ac3 sound, I have no sound. If I want to recover it, I must go to a channel with no AC3 before start the reading.
Example: you record an encrypted SD channel (with no AC3).
When you want to read it again, the channel on which you are before you start the Media Center has an influence.
If you are on an HD channel (AC3) encrypted, you will have the black image no sound.
If you are on an encrypted SD channel (no AC3), you'll have just the sound.
If you are on a SD channel not encrypted (FTA) you will have sound and image ...
