I decided not to release V1.4 which was only tested by a few people. I left it as an internal release since I was not convinced with it because of some bugs. I added new features to V1.5 and solved all bugs that I found. This is the most stable and most powerful release of PRIORITY MANAGER.
I hope you like it !
Note: Again I asked help from Opensat for this release and got nothing
At first FatGiant said that they will help, but then again they don't respond my PM's. I solved all problems with my self. Opensat really needs a separate department to assist volunteer developers.
PLEASE READ "INSTALLATION" SECTION BEFORE ASKING OR COMPLAINING ABOUT SOMETHING!, THANKS....
DESCRIPTION:
This plugin is written by BUYUKBANG to improve total performance of Azbox HD and add its
missing features! However its name remains as "Priority Manager", it now makes more than
its name is offering. Here are the features of Priority Manager:
* Priority Manager automatically changes the priorities of the processes to give optimal
performance for the menu being used. I tested all processes one by one, decided their
effects on the performance of all modules and prepared a bug-free (hopefully) and complex
logic to cover all possible usage cases.
* Priority Manager provides power saving! Smudger's power measurements show that
Priority Manager decrease power consumption of the box from 25W to 23W while watching an
SD channel and from 28W to 24W while watching an HD channel.
* Priority Manager provides password protected hidden channel list feature. This will
cover missing function in Azbox and so that you will be able to prepare a separate hidden
channel list which you want hide from people not knowing your password. Default channel
list will be automatically replaced, so that any reboots / electricity problems will not
reveal this second channel list.
* You can backup or restore /DISK2 and /PLUGINS folders with just a simple button from
user interface.
* Priority Manager optionally takes backup of /DISK2 and /PLUGINS folders in user defined
periods in background.
* Priority Manager upgrades Busybox from v1.0 to v1.16.
* Priority Manager enables Cron usage.
* Priority Manager can move plugins to internal HDD or USB storages.
* Priority Manager optionally automatically mounts CIF and NFS shares when remote server
is online and automatically unmounts CIF AND NFS shares when remote server is offline, so
protects file manager from freezes when remote goes offline after the shares mounted.
* Priority Manager optionally creates swap file on your HDD/Flash disk which will help
RAM by caching some part of the memory. Priority Manager not only supports creating swap
file on internal HDD or usb HDD/Flash disk connected before Azbox boots, it also supports
creating swap file on usb HDD/Flash disk connected after Azbox boots by continuously
checking for new USB devices.
* Priority Manager can execute user selected programs after going into SLEEP mode and
the kill them after return from SLEEP mode. By using this feature running resource
intensive programs like transmission, aMule, azepgmgr in only SLEEP mode will be
automatically managed without user intervention.
* Priority Manager increases internal storage (DOM) speed speed up to 20% by changing
its working parameters.
* Priority Manager provides "Deep Sleep Mode" which automatically kills all unnecessary
applications and improve downloading speed when box goes to sleep mode.
* Up on deactivating or uninstalling Priority Manager, if related features activated in
/DISK2/etc/PriorityManagerSettings.txt, Busybox downgrades to the orginal version,swap file
and cron is deactivated all mounted shares are unmounted and plugins are moved back to
original place. A complete rollback without reboot requirement is performed.
SPECIAL THANKS TO:
Smudger for the all information, tests and power measurements, his tests killed the bugs!
Kanber Kav for his permission for the usage and modification of his Multicas Info plugin
and for the idea of increasing internal storage (DOM) speed!
Bug Reports
If you have any problems with Priority Manager, activate VERBOSE LOG from user interface
and restart Priority Manager from PLUGINS-->PriorityManager-->Activate/Reactivate.
This will create a verbose log file /Download/PriorityManager_Verbose_Log . Collect data
with this option set to 1, without stopping, restarting, reactivating and deactivating
Priority Manager, because all this operations will delete all old log files. Then send an
e-mail to buyukbang @ gmail.com containing PriorityManager_Verbose_Log with the approximate
time that problem occured.
HISTORY:
v1.5
NEW: User interface is completely reworked. Toggling all settings from user interface
without any need for using TELNET / FTP is now possible. Added a button to user interface
to review current settings.
NEW: Password protected hidden channel list feature is added.
NEW: Backup /DISK2 and /PLUGINS folder from user interface is added.
NEW: Restore last backup of /DISK2 and /PLUGINS folders from user interface is added.
FIX : Fixed some bugs in "Move Plugins" feature.
v1.4
This was an internal release and only a few testers got this version.
NEW : Faster menu detection algorithm which dynamically manages sleep time between loops.
NEW : Busybox can be upgraded automatically in boot from v1.0 to v1.16 with a simple
option in PriorityManagerSettings.txt (Thanks to Kanber Kav for compiling Busybox!)
NEW : Full automated Cron setup. Cron provides a very flexible UNIX scheduling mechanism.
NEW : Moving plugins to internal HDD or USB storages.
NEW : Scheduled backup of /DISK2 and /PLUGINS folders in user defined periods.
NEW : Improved user interface on Plugins Menu. (Thanks to Kanber Kav for the new version of
his Multimenu plugin!)
NEW : Improvement on automatic management of execution and killing programs: Priority
Manager can start user selected programs when Azbox sleeps. When Azbox wakes up there are
3 things that priority manager can do as an opposite action: kill it, start another
script to stop it or simply do nothing which can be useful if it's a auto-terminated
program or script.
NEW: Better and faster recording detection algorithm.
NEW: Mount checks simplified and tuned for better performance. Now you can mount CIF/NFS
shares directly to HDD folders without using symlinks to DOM folders.
NEW: Improved swap file support. Creation of swap file is now retried when "SWAP FILE
ACTIVATION FAILED" error occurs.
NEW : Up on deactivating or uninstalling Priority Manager, if related features activated
in /DISK2/etc/PriorityManagerSettings.txt, Busybox downgrades to the orginal version, swap
file and cron is deactivated,all mounted shares are unmounted and plugins are moved back
to original place. So a complete rollback without reboot requirement is performed.
NEW : Limiting file size of PriorityManager_Verbose_Log with the given byte value.
FIX : HDD not sleeps when reserved programs are waiting to be recorded.
http://uploaded.to/file/nboiwf
DESCRIPTION:
user interface.
SPECIAL THANKS TO:
Bug Reports
HISTORY:
v1.5
v1.4
program or script.
