OpenSpa 4.0.004 and dvb-t usb rtl2832u
Maxbambi
23 Jun 2014
My rtl2832 dvb-t usb key doesn't work
root@azboxhd:~# modprobe rtl2832-sdr
modprobe: ERROR: could not insert 'rtl2832_sdr': Unknown symbol in module, or unknown parameter (see dmesg)
[45784.820000] rtl2832_sdr: Unknown symbol vb2_queue_init (err 0)
[45784.820000] rtl2832_sdr: Unknown symbol vb2_ioctl_streamoff (err 0)
[45784.830000] rtl2832_sdr: Unknown symbol vb2_ops_wait_finish (err 0)
[45784.840000] rtl2832_sdr: Unknown symbol vb2_ioctl_querybuf (err 0)
[45784.850000] rtl2832_sdr: Unknown symbol vb2_fop_release (err 0)
[45784.850000] rtl2832_sdr: Unknown symbol vb2_ioctl_dqbuf (err 0)
[45784.860000] rtl2832_sdr: Unknown symbol vb2_ioctl_create_bufs (err 0)
[45784.870000] rtl2832_sdr: Unknown symbol vb2_ioctl_prepare_buf (err 0)
[45784.880000] rtl2832_sdr: Unknown symbol vb2_buffer_done (err 0)
[45784.890000] rtl2832_sdr: Unknown symbol vb2_plane_vaddr (err 0)
[45784.900000] rtl2832_sdr: Unknown symbol vb2_ioctl_qbuf (err 0)
[45784.900000] rtl2832_sdr: Unknown symbol vb2_fop_mmap (err 0)
[45784.910000] rtl2832_sdr: Unknown symbol vb2_vmalloc_memops (err 0)
[45784.920000] rtl2832_sdr: Unknown symbol vb2_fop_read (err 0)
[45784.930000] rtl2832_sdr: Unknown symbol vb2_ops_wait_prepare (err 0)
[45784.930000] rtl2832_sdr: Unknown symbol vb2_ioctl_streamon (err 0)
[45784.940000] rtl2832_sdr: Unknown symbol vb2_fop_poll (err 0)
[45784.950000] rtl2832_sdr: Unknown symbol vb2_ioctl_reqbufs (err 0)
root@azboxhd:~# lsmod
Module Size Used by
v4l2_dv_timings 21489 0
dvb_usb_rtl28xxu 19569 0
rtl2832 10628 2 dvb_usb_rtl28xxu
ipv6 295421 25
v4l2_common 4636 0
videodev 151252 1 v4l2_common
media 14798 1 videodev
r820t 18843 1
rtl2830 7321 1 dvb_usb_rtl28xxu
dvb_usb_v2 17012 1 dvb_usb_rtl28xxu
spa_rc_core 24451 3 dvb_usb_v2,dvb_usb_rtl28xxu
spa_dvb_core 97556 3 dvb_usb_v2,rtl2832,rtl2830
boxmodel 939 0
tun 16439 0
rt61pci 25023 0
rt2x00pci 5197 1 rt61pci
rt2x00lib 44847 2 rt2x00pci,rt61pci
eeprom_93cx6 2604 1 rt61pci
mac80211 245570 2 rt2x00lib,rt2x00pci
pl2303 14224 0
option 16565 0
usb_wwan 10937 1 option
usbserial 39365 3 usb_wwan,option,pl2303
nfs 200093 0
lockd 88703 1 nfs
sunrpc 250794 3 lockd,nfs
863xdvb 1131534 30
sci 33785 2
nimdetect 4438 1 863xdvb
az_zl10353 7022 1 nimdetect
az_tda10023 7114 1 nimdetect
az_stv090x 68962 1 nimdetect
az_stv6110x 5052 1 nimdetect
az_mxl5007t 7815 1 nimdetect
az_mxl201rf 7883 1 nimdetect
az_cx24116 17892 1 nimdetect
863xi2c 17520 9 az_cx24116,az_mxl201rf,az_mxl5007t,az_stv6110x,az_stv090x,az_tda10023,az_zl10353,nimdetect,863xdvb
em8xxx 2506251 2 863xi2c,863xdvb
llad 109158 3 em8xxx,863xi2c,863xdvb
irvfd 12004 4 az_tda10023,az_zl10353,nimdetect,863xdvb
hook 2275 5 llad,irvfd,em8xxx,sci,863xdvb
someone can help me?
lilo74
2 Oct 2011
681
70
what kind of USB is DVB-T, o DVB-C??? It should work well in both cases.
Maxbambi
23 Jun 2014
It's dvb-t usb key... I have installed this key in windows and linux and works, now I would like to use it with Azbox...
This is the part of dmesg in relationship with the key...
[ 43.570000] usb 1-2: dvb_usb_v2: found a 'Realtek RTL2832U reference design' in warm state
[ 43.660000] usb 1-2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 43.680000] SPA-DVB: registering new adapter (Realtek RTL2832U reference design)
[ 43.760000] i2c i2c-1: Added multiplexed i2c bus 2
[ 43.770000] i2c i2c-1: Added multiplexed i2c bus 3
[ 43.800000] usb 1-2: DVB: registering adapter 1 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 43.910000] MBUS: error previous command is pending (0:4) ...
[ 43.920000] r820t 1-001a: creating new instance
[ 43.940000] r820t 1-001a: Rafael Micro r820t successfully identified
[ 44.050000] media: Linux media interface: v0.10
[ 44.180000] Linux video capture interface: v2.00
[ 44.180000] WARNING: You are using an experimental version of the media stack.
[ 44.180000] As the driver is backported to an older kernel, it doesn't offer
[ 44.180000] enough quality for its usage in production.
[ 44.180000] Use it with care.
[ 44.180000] Latest git patches (needed if you report a bug to [email protected]):
[ 44.180000] e32b31ae45c18679c186e67aa41d0e2318cae487 [media] mb86a20s: remove unused debug modprobe parameter
[ 44.180000] 551c33e729f654ecfaed00ad399f5d2a631b72cb [media] Si2168: increase timeout to fix firmware loading
[ 44.180000] 92ced56d06a9c5cfa3ef3b628068c36fd3c34786 [media] mn88472: add 5MHz dvb-t2 bandwitdh support
[ 44.350000] rtl2832_sdr: Unknown symbol vb2_queue_init (err 0)
[ 44.350000] rtl2832_sdr: Unknown symbol vb2_ioctl_streamoff (err 0)
[ 44.380000] rtl2832_sdr: Unknown symbol vb2_ops_wait_finish (err 0)
[ 44.400000] rtl2832_sdr: Unknown symbol vb2_ioctl_querybuf (err 0)
[ 44.400000] rtl2832_sdr: Unknown symbol vb2_fop_release (err 0)
[ 44.420000] rtl2832_sdr: Unknown symbol vb2_ioctl_dqbuf (err 0)
[ 44.420000] rtl2832_sdr: Unknown symbol vb2_ioctl_create_bufs (err 0)
[ 44.440000] rtl2832_sdr: Unknown symbol vb2_ioctl_prepare_buf (err 0)
[ 44.440000] rtl2832_sdr: Unknown symbol vb2_buffer_done (err 0)
[ 44.460000] rtl2832_sdr: Unknown symbol vb2_plane_vaddr (err 0)
[ 44.460000] rtl2832_sdr: Unknown symbol vb2_ioctl_qbuf (err 0)
[ 44.480000] rtl2832_sdr: Unknown symbol vb2_fop_mmap (err 0)
[ 44.480000] rtl2832_sdr: Unknown symbol vb2_vmalloc_memops (err 0)
[ 44.500000] rtl2832_sdr: Unknown symbol vb2_fop_read (err 0)
[ 44.500000] rtl2832_sdr: Unknown symbol vb2_ops_wait_prepare (err 0)
[ 44.520000] rtl2832_sdr: Unknown symbol vb2_ioctl_streamon (err 0)
[ 44.550000] rtl2832_sdr: Unknown symbol vb2_fop_poll (err 0)
[ 44.550000] rtl2832_sdr: Unknown symbol vb2_ioctl_reqbufs (err 0)
[ 44.580000] Registered IR keymap rc-empty
[ 44.600000] input: Realtek RTL2832U reference design as /devices/pci0000:00/0000:00:02.2/usb1/1-2/spa-rc/rc0/input1
[ 44.630000] rc0: Realtek RTL2832U reference design as /devices/pci0000:00/0000:00:02.2/usb1/1-2/spa-rc/rc0
[ 44.670000] usb 1-2: dvb_usb_v2: schedule remote query interval to 400 msecs
[ 44.700000] usb 1-2: dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialized and connected
[ 44.740000] usbcore: registered new interface driver dvb_usb_rtl28xxu
