Nuevo archivo para descargar: MultiCASEdit 1.3
Yersi
18 Mar 2007
6.647
793
Nuevo archivo para descargar añadido por Yersi_AP:
MultiCASEdit 1.3
MultiCASEdit
v.1.3
Add:
- Uphops set in C: line
v.1.2
Add:
- CCcam Status , get info of server status(on/off) and ecm info
- Edit Serever lines - now simply , you can add C: line
- Auto update of changes
v.1.1
Fix:
Bug when load wrong Key.bin file - program crash
Add:
- now, you can edit splitter data
- if file : splitterdata.bin , will be created
v.1.0
Small tool to manage your cccam and multicas data.
After succesfull installation, use the options tab to edit settings
for the ftp connection to your az box.
After that you will be able to upload / download / edit data from your box.
