Aqui teneis el changelog de las versiones hasta ahora:
0.6 BETA build 0002
-Fix debug text not showing on PPC.
-Few changes in msms code , need testing.
0.6 BETA build 0001
-Changed how msms works,now messages from Leete las normas will be in seperated files called "msms_peerIP_date_time.txt".
0.6 BETA build 0000
-Changed Z line in mbox.cfg! Added flag to disable writing debug text in console window.
-Fixed problem with connections.
-Removed TCP code/connection.
-Protocol Version number is 01.0C.
-Removed connection to old 0.5 mbox versions.
Las grabaciones no he podido probarlas, asi que el que las pruebe que postee. Si nadie lo hace yo echare un ratito mañana por la mañana haciendo pruebas y comentare.
Yes, thank you but of no use for us... we need better OpenXCAS with stop camd without killall but command line. Currently we cannot stop mbox via touch /tmp/mbox.kill with OpenXCAS... that is really bad. Only killall option and no way to use scripts to run camd like Enigma.
