- 4 Abr 2011
- 23
Tengo una tarjeta gris de pago al corriente en un Azbox Premium Hd. Cada dos meses aproximadamente, para actualizar la fecha de validez, o tengo que llamar por telefono, o tengo que meterla en el deco oficial, y es una lata.
La veo con Sbox, sin problemas, pero no me la actualiza.
Me he leido un monton de posts y creo que la configuración está bien, pero no actualiza.
Tengo configurado sbox así:
[main]
server_only=0 # 0=camd+newcamd server 1=only newcamd server
log=0 # 0=no log 1=log to /tmp/sbox.log //ALWAYS USE 0//
userspath= /PLUGINS/OpenXCAS/SboxCAS/users.sbox # users list
webinterface=1 # 1eb interface on 0eb interface off
webport=81 # web interface port
[slot0]
active=1 # 0=inactive 1=active
sci=/dev/scard # lower
ncdserver=1 # 0=newcamd server off 1=newcamd server on
deskey=0102030405060708091011121314 # newcamd deskey
port=20000 # newcamd port
mhz=368 # Mhz for card in this reader, ONLY WORKS ON INTERNAL CARDREADER
#Nagra2/3 Example
[xxxxx] # nagra2 camid (4 bytes)
rsa= xxxxxxx # rsa "n" from this card (like newcs)
boxkey= xxxxxxx # boxkey from this card
emm=0 # 0=accept all 1=block emms 2=block emmu 4=block emmg
#portlist=0 # use portlist or no
#portlistpath=/var/****/port.list # path from port.list
#Nagra tiger/ncmed Example
[CCCCCCCC] # nagra camid (4 bytes)
portlistpath= # path from port.list
#Seca Example
[CCCCCCCC] # seca camid (4 bytes)
ok_view=0 # if ok_view=1 sbox simulates the "ok view this season" on seca smartcards
#Viaccess Example
[CCCCCCCC] # via camid (4 bytes)
aeskey= # aeskey used by nano d2
#Irdeto Example
[CCCCCCCC] # irdeto camid (4 bytes)
camkey=0000000000000000 # CamKEY
camkeydata=000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000
#NDS Example
[CCCCCCCC] # nds camid (4 bytes)
boxid= # if sbox can't get boxid from card, add here manually
#Conax Example
[CCCCCCCC] # conax camid (4 bytes)
#Example configuration newcamd client
[NewCamd]
#server0=dummy:dummy@localhost:15050/0102030405060708091011121314/0
#server1=dummy:dummy@localhost:15051/0102030405060708091011121314/2
#server2=dummy:dummy@localhost:15052/0102030405060708091011121314/7
En todos los emm he puesto 0 pero ni así actualiza.
¿Que estoy haciendo mal?
Gracias por vuestra ayuda.
[main]
[slot0]
#Nagra2/3 Example
#Seca Example
#Viaccess Example
#Irdeto Example
#NDS Example
#Conax Example
[NewCamd]
