- 19 Mar 2007
- 9.176
- 1.168
Este es el log del server que nos ha tenido offline todo el dia, ha sido ajeno a nosotros ya que era un mantenimiento donde tenemos contratado el vps pero han tenido alguna complicacion que ha llevado todo el dia solucionarla:
FS#53 - Maintenance on all OpenVZ-Nodes
In order to ensure the stable operation of all OpenVZ-Nodes we will upgrade the kernel of the following systems and made it future proof.
- vnode04
- vnode05
- vnode06
- vnode07
- vnode08
- vnode09
- vnode10
We expect an normal upgrade, so that the downtime is estimated to be about 30 minutes for each node. We are sorry for any inconvenience but this maintenence should be in your mind. Please check this page for further updates.
[19.12.2014 10:00 CET]: vnode04 is shutting down and the maintenance begins.
[19.12.2014 10:10 CET]: vnode04 and all VPS are booting now. Please do not boot your VPS manually.
[19.12.2014 10:11 CET]: vnode05 is shutting down and the maintenance begins.
[19.12.2014 10:14 CET]: vnode05 and all VPS are booting now. Please do not boot your VPS manually.
[19.12.2014 10:17 CET]: vnode06 is shutting down and the maintenance begins.
[19.12.2014 10:19 CET]: vnode04 - all VPS are online again.
[19.12.2014 10:21 CET]: vnode06 and all VPS are booting now. Please do not boot your VPS manually.
[19.12.2014 10:21 CET]: vnode05 - all VPS are online again.
[19.12.2014 10:31 CET]: vnode07 is shutting down and the maintenance begins.
[19.12.2014 10:37 CET]: vnode07 and all VPS are booting now. Please do not boot your VPS manually.
[19.12.2014 10:39 CET]: vnode08 is shutting down and the maintenance begins.
[19.12.2014 10:43 CET]: vnode06 - all VPS are online again.
[19.12.2014 10:46 CET]: vnode08 and all VPS are booting now. Please do not boot your VPS manually.
[19.12.2014 10:48 CET]: vnode07 - all VPS are online again.
[19.12.2014 10:50 CET]: vnode08 has to rebuild the raid and therefore the performance will be decreased for round about 2 hours. We are sorry for this inconvenience.
[19.12.2014 10:52 CET]: vnode09 is shutting down and the maintenance begins.
[19.12.2014 11:05 CET]: vnode09 and all VPS are booting now. Please do not boot your VPS manually.
[19.12.2014 11:10 CET]: vnode10 is shutting down and the maintenance begins.
[19.12.2014 11:13 CET]: vnode08 - all VPS are online again.
[19.12.2014 11:20 CET]: vnode10 and all VPS are booting now. Please do not boot your VPS manually.
[19.12.2014 11:42 CET]: vnode10 - we had to reboot the node again due to some problems. All VPS will boot again, so please do not boot your VPS manually.
[19.12.2014 11:47 CET]: vnode09 - we had to reboot the node again due to some problems. All VPS will boot again, so please do not boot your VPS manually.
[19.12.2014 12:29 CET]: vnode10 - we had to start a FS-Check and therefore the node is still unreachable.
[19.12.2014 12:32 CET]: vnode09 - all VPS are online again. Please note that the raid rebuild is still in process and the performance is decreased.
[19.12.2014 14:06 CET]: vnode10 - The filesystem check is still running and is now at 26 percent. This process need time and we can not estimate the needed time to finish this. We are very sorry about this, but we work hard to solve this issue. Thank you in advance for your understanding.
[19.12.2014 14:49 CET]: vnode10 - Current status of FS-Check: 30.8 percent
[19.12.2014 15:25 CET]: vnode10 - Current status of FS-Check: 36.3 percent
[19.12.2014 16:13 CET]: vnode10 - Current status of FS-Check: 37.7 percent
[19.12.2014 17:43 CET]: vnode10 - Current status of FS-Check: 49.6 percent
[19.12.2014 19:21 CET]: vnode10 - Current status of FS-Check: 61.5 percent
[19.12.2014 29:59 CET]: vnode10 - all vps are booting now
[20.12.2014 00:08 CET] All VPS are now up and running. We are very sorry for any trouble this downtime has caused.
- vnode04
- vnode05
- vnode06
- vnode07
- vnode08
- vnode09
- vnode10
