- 6 May 2009
- 98
Muy buenas,
Sigo con mis problemas con el Mbox 04.23 y el MCC.
No se bien que me puede estar impidiendo ver a la gente en on (y recibir los datos), apenas llevo un dia con esto pero ayer consegui ver un par de Leete las normas en verde, y hoy todos gris y los dos d eayer en rojo, aunque se supone que estan on. Os escribo lo que me dice el putty ligeramente editado por si a alguien se le ocurre alguna idea.
MMP login: root
Password:
MMP[~]$ cd /camd/OpenXCAS/MboxCAS/
MMP[MboxCAS]$ chmod 755 mbox_module
MMP[MboxCAS]$ ./mbox_module
[22:35:38] Checking for priority file ... total priority lines 35
[OPENXCAS_API:Thu Jul 30 22:35:38.058] openxcas_open:106 ## MboxCAS
[OPENXCAS_API:Thu Jul 30 22:35:38.063] load_xcas_control:66 ## loaded controller ID = 0x19760507
osdep_msq_server_open : key_request 0x2FE78453 key_response 0x2FE78454
osdep_msq_server_open : request msq is already created
osdep_msq_server_open : response msq is already created
osdep_msq_client_connect : key_request 0x2FE78453 key_response 0x2FE78454
[22:35:38] ExYuSAT Team [url]http://www.exyusat.com[/URL] , [url]http://mbox.exyusat.com/index[/URL]. php
[22:35:38] Starting MBOX version 0.4 BETA (build 0023) coded by The_Ripper
[22:35:38] This program is for educational & informational purposes only!!
[22:35:38] Donation to project: [url]http://mbox.exyusat.com/donate.htm[/URL]
[22:35:38] ===> Net Mode <===
MMP[MboxCAS]$ [22:35:38] Reading cwshare.cfg ...
[22:35:38] Trying to get online,please wait ...
[22:35:38] My IP 083.0xx.xxx.054 ID 4553 (xxxx.dyndns.org) pass xxxxxxxx, we are ONLINE
[22:35:38] IP xxxxxxxxxxxxxx Port 8000-xxxxx ID D86C pass xxxxxxxx sharelevel 0 3/03
[22:35:40] Total 1 UDP port(s) to monitor
[22:35:40] Total 0 TCP port(s) to monitor
[22:35:40] Monitoring port(s): 8000
[22:35:40] Creating ecm parser thread ...OK
[22:35:40] Creating openxcas API receive thread ...OK
[22:35:40] Creating timer thread ...OK
[22:35:40] Creating send thread ...OK
[22:35:40] Creating UDP receive thread ...OK
[22:35:40] [gbox]->Hello to peer (xxxxxxxxxx.dyndns.org:xxxxxx)
[22:35:41] [gbox]<-Hello from peer xxxxxxxxxxxxxx.no-ip.org port xxxxx
MMP login: root
Password:
