I'm trying to set swapfile in in-memory which is "root/swapfile", the file is created by swap manager but it doesn't work. How to do it on openATV internal memory ?
Estas en el foro de OpenSPA, como preguntas por una configuración para OpenATV, tendras que preguntar en su foro mejor.
You are in the OpenSPA forum, as you ask for a configuration for OpenATV, you will have to ask in their forum better.
