- 5 Dic 2011
- 145
- 17
Many thanks @Mecha,inserted in this place, as you pointed out, it works Another question, as you know, after downloaded each new version of Spark, removed busybox.sh4 and need to reinstall it, the command to install busybox in /sbin, or you can this command to assign a plug-in ? I tried that but not working through the plugin, using the command in telnet, like most works, but I need busybox to install using the plugin, I tried and not working :
#!/bin/sh
busybox.sh4 --install -s /usr/local/sbin
