- 11 Ago 2009
- 199
- 4
For owners of an Infinity USB Smart external cardreader, this is the way to make it work on your Azbox Me with Neutrino HD and E2, using c**am.
- Place the attached driver-file in the /tmp folder of the Azbox Me
- Open a Telnet session and give the following commands:
cd /tmp
ipkg install azboxme-usbserial-drivers_20111013_mipsel.ipk
- Assuming you have c**am running, add the following line to your cfg-file:
SERIAL READER : /dev/ttyUSB0 smartreader+
Reboot your Azbox Me and you should be ok to use the Infinity USB Smart cardreader.
IMPORTANT: You should programm your Infinity USB Smart as a smartreader+.
cd /tmp
