- 10 Abr 2009
- 1.334
- 9
System info plugin for Enigma2 OE 1.6
- if you have CCcam in your dream only, you dont need cccam_servers.cfg -
delete it - if you managing many servers, simly edit cccam_servers.cfg
- if you want change design, simply edit the file - GSU_skins.py
enjoy
note: plugin works on OE 1.6 images
Glass System Utility - update - ver 1.9
- added displaying blocked servers/clients (using # like #C: server....,
#N: .... #F: ..... in the file cccam.cfg)
- added enable/disable server/client via 1-button (green/blue) - all changes
are applyed immediate - after change refresh begin automaticaly
- added manual refresh button in screens servers/clients
- added short start some screens via "short blue button" - working in CVS
images only
- added short start some screens via plugins
- added extra view in CCcam info
- added new item in main menu: Ipk and User script
1.you can manage ipk packages - install/remove any one in your dm,
2. run own script - see small help in menu - plugin have 3 "user scripts", you can create and run own,
3. unpack gz/bz2 packages
- added/changed autorefresh of ECMinfo in UCM
- fix hdd info in system info
- small changes in channel info, new ecm ifo script - hex values of pids, sid, onid...
- new design of main screen - (red - disabled item, red - enabled item - this works in all submenus/screens)
- added autodetect the version of cccam in cccam info
- new cfg file for remote servers ( cccam and oscam) - remote_servers.cfg - placed in /etc
- added OSCAM INFO - autorefresh in screens: status, users, loadbalance - must be oscam compiled with webinterface, works only if the httppass is not defined (empty), there is a problem reading info via web when pass is defined ( probably due to an error in webinterface)
- added OSD ECM INFO - new special function, works in two modes: 1. static window - showed if a change to any item with a scheduled - you can define position, threshold of Ecm time and viewing time, 2. the window with rolled infos - show only the changed items of all ecm items - you can define position and threshold of Ecm time
- added detection of DRE Crypt CAS (all screens with Ecm info)
- added detection of Bulcrypt CAS (all screens with Ecm info)
- added all caids in channel info
How to install, thanx to deki20:
enjoy
images only
Copy to /tmp.
In telnet [PuTTy, for instance] C&P:
Código:ikpg install /tmp/enigma2-plugin-glasssysutil_2.39_mipsel.ipk
After restart delete the file from /tmp folder.
I added a smaller version [it doesn't have the cams, which one has to download from the net using the plugin, whereas this one installs it all immediately
Código:http://www.sat-universe.com/attachment.php?attachmentid=243040&d=1288439232
The thread is here:
Código:http://www.sat-universe.com/showthread.php?t=178063
