root@gbultraue:~# init 4
root@gbultraue:~# enigma2
PYTHONPATH: /usr/lib/enigma2/python
DVB_API_VERSION 5 DVB_API_VERSION_MINOR 10
< 744.373803> + (1) Background File Eraser
< 744.375082> + (5) Tuxtxt
< 744.375390> + (8) graphics acceleration manager
< 744.376104> + (9) GFBDC
< 744.376422> 24300k video mem
< 744.377370> - double buffering available!
< 744.401077> 17100kB available for acceleration surfaces.
< 744.401339> resolution: 1280 x 720 x 32 (stride: 5120)
< 744.401614> + (9) gLCDDC
/dev/fb1: No such file or directory
framebuffer not available.
< 744.404703> lcd buffer 0x7bc888 77440 bytes, stride 440
< 744.405098> LCD resolution: 220 x 176 x 16 (stride: 440)
< 744.405207> + (9) Font Render Class
< 744.405318> [FONT] initializing lib...
< 744.405827> [FONT] loading fonts...
< 744.406156> [FONT] Intializing font cache, using max. 4MB...
< 744.406529> + (10) gRC
< 744.407948> RC thread created successfully
< 744.408411> + (15) eWindowStyleManager
< 744.408534> + (20) DVB-CI UI
< 744.408635> + (20) UHF Modulator
< 744.408795> couldnt open /dev/rfmod0!!!!
< 744.408885> + (20) RC Input layer
< 744.408977> + (20) misc options
< 744.409233> + (20) AVSwitch Driver
< 744.409362> couldnt open /dev/dbox/fp0 to monitor vcr scart slow blanking changed!
< 744.409454> + (21) input device driver
consoleFd 9
EVIOCGRAB: Device or resource busy
< 744.409962> Input device "gigablue remote control" is a remotecontrol
< 744.410370> Found 1 input devices.
< 744.410480> + (22) Hdmi CEC driver
< 744.410757> + (30) eActionMap
< 744.410909> + (35) CI Slots
< 744.411245> scanning for common interfaces..
< 744.412499> CI Slot 0 setSource(0)
< 744.413555> eDVBCIInterfaces->setInputSource(0, 0)
< 744.414396> eDVBCIInterfaces->setInputSource(1, 1)
< 744.414587> done, found 1 common interface slots
< 744.414686> + (35) CA handler
< 744.415849> + (40) eServiceCenter
< 744.416267> settings instance.
< 744.416404> + (41) eServiceFactoryDVD
< 744.416544> + (41) eServiceFactoryHDMI
< 744.416634> + (41) eServiceFactoryM2TS
< 744.416741> + (41) eServiceFactoryMP3
< 744.416991> + (41) eServiceFactoryFS
< 744.417172> + (41) eServiceFactoryDVB
< 744.417297> + (41) Encoders
< 744.417542> + (41) Stream server
< 744.418597> [eServerSocket] ERROR on bind: Address already in use
< 744.420272> [eServerSocket] ERROR on bind: Address already in use
< 744.420658> reached rl 70
< 744.420843> ---- opening lame channel db
< 744.421242> reading services (version 4)
< 744.421494> loaded 0 channels/transponders and 0 services
< 744.444618> [eDVBUsbAdapter] linking adapter1/frontend0 to vtuner0
< 744.506782> [eDVBUsbAdapter] linking adapter2/frontend0 to vtuner1
< 744.518723> [eDVBResourceManager] scanning for frontends..
< 744.519297> opening frontend 0
< 744.526191> close frontend 0
< 744.527665> opening frontend 1
< 744.541123> close frontend 1
< 744.546974> opening frontend 2
< 744.577412> close frontend 2
< 744.578225> opening frontend 3
< 744.624211> close frontend 3
< 744.624697> [eDVBAdapterLinux] get demux 0
< 744.624760> [eDVBAdapterLinux] get demux 1
< 744.624806> [eDVBAdapterLinux] get demux 2
< 744.624853> [eDVBAdapterLinux] get demux 3
< 744.624900> [eDVBAdapterLinux] get demux 4
< 744.625175> [eDVBResourceManager] found 3 adapter, 4 frontends(4 sim) and 5 demux
< 744.625458> Use valid Linux Time
(RTC?)
< 744.625606> [EPGC] Initialized EPGCache (wait for setCacheFile call now)
< 744.629999> Loading spinners...
< 744.672818> [ePNG] couldn't open /usr/share/enigma2/skin_default/spinner/wait7.png
< 744.673228> found 6 spinner!
executing main
< 744.673795> setIoPrio best-effort level 3 ok
< 746.840302> Failed to open /dev/dbox/fp0
< 746.842147> couldn't open /proc/stb/misc/12V_output
[Harddisk] enumerating block devices...
new Harddisk sda -> /dev/sda -> /dev/sda
[ePopen] command: ('hdparm', 'hdparm', '-S0', '/dev/sda')
[Harddisk] enumerating network mounts...
loading display skin skin_display.xml
< 748.408306> main thread is non-idle! display spinner!
Reading satellites.xml
Reading cables.xml
Reading terrestrial.xml
sec config cleared
< 752.792114> setSlotInfo for dvb frontend 0 to slotid 0, descr BCM7362 DVB-S2 NIM (internal), need rotorworkaround No, enabled Yes, DVB-S2 Yes
< 752.798071> setSlotInfo for dvb frontend 1 to slotid 1, descr GIGA DVB-S2 NIM (SP2246T), need rotorworkaround No, enabled Yes, DVB-S2 Yes
< 752.798286> setSlotInfo for dvb frontend 2 to slotid 2, descr SCEH-0036, need rotorworkaround No, enabled Yes, DVB-S2 No
< 752.798400> setSlotInfo for dvb frontend 3 to slotid 3, descr SCEH-0036, need rotorworkaround No, enabled Yes, DVB-S2 No
slot: 0 configmode: simple
diseqcmode: single
slot: 1 configmode: advanced
add 192 to 1
sec config completed
[Picon] adding path: /usr/share/enigma2/
< 756.015272> loading bouquet... /etc/enigma2//bouquets.tv
< 756.018501> loading bouquet... /etc/enigma2//userbouquet.favourites.tv
< 756.019743> 0 entries in Bouquet userbouquet.favourites.tv
< 756.020840> 1 entries in Bouquet bouquets.tv
< 756.025328> loading bouquet... /etc/enigma2//bouquets.radio
< 756.029216> loading bouquet... /etc/enigma2//userbouquet.favourites.radio
< 756.030384> 0 entries in Bouquet userbouquet.favourites.radio
< 756.031418> 1 entries in Bouquet bouquets.radio
< 756.032361> Renumbering...
[Time By]: Transponder
< 756.347538> [EPGC] time updated.. but cache file not set yet.. dont start epg!!
[FONT] adding font /usr/share/fonts/nmsbd.ttf...< 758.813910> OK (Regular)
[FONT] adding font /usr/share/fonts/andale.ttf...< 758.821995> OK (Fixed)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...< 758.830360> OK (Console)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...< 758.832171> OK (Replacement)
[FONT] adding font /usr/share/enigma2/confluence_openspa/fonts/valis_lcd.ttf...< 758.894171> OK (LCD)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...< 758.895924> OK (Console)
[FONT] adding font /usr/share/enigma2/confluence_openspa/fonts/robotobold.ttf...< 758.898592> OK (Bold)
[FONT] adding font /usr/share/enigma2/confluence_openspa/fonts/robotoregular.ttf...< 758.903292> OK (Regular)
[FONT] adding font /usr/share/fonts/LiberationSans-Regular.ttf...< 759.017614> OK (Subs)
[FONT] adding font /usr/share/fonts/LiberationSans-Italic.ttf...< 759.033213> OK (Subsi)
[FONT] adding font /usr/share/fonts/LiberationSans-Bold.ttf...< 759.045863> OK (Subsb)
[FONT] adding font /usr/share/fonts/LiberationSans-BoldItalic.ttf...< 759.058424> OK (Subsz)
[FONT] adding font /usr/share/fonts/tuxtxt2.ttf...< 759.078767> OK (Consola)
[FONT] adding font /usr/share/fonts/hd2.ttf...< 759.080335> OK (VFD)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
Activating keymap: Default (US)
[ePopen] command: loadkmap < /usr/share/keymaps/default.kmap
Activating language Espa ol
[VideoMode] setting aspect: 16:9
[VideoMode] setting wss: auto
[VideoMode] setting policy: panscan
[VideoMode] setting policy2: letterbox
[VideoMode] setting scaler_sharpness to: 0000000D
[VideoMode] setMode - port: HDMI, mode: 1080p, rate: multi
[ePopen] command: ip -o addr show dev eth0
Setting OSD position: 14 692 12 553
Setting OSD alpha: 255
Setting 3D mode: auto
Setting 3D depth: 50
< 762.991922> FIXME: request for unknown slot
< 762.998567> FIXME: request for unknown slot
< 763.003771> FIXME: request for unknown slot
[OpenSPAPlug] set language to es
Plugin Extensions/WebInterface failed to load: No module named plugin
Plugin probably removed, but not cleanly in /usr/lib/enigma2/python/Plugins/Extensions/WebInterface
[DeviceManager] fallback to default translation for: Device Manager
[DeviceManager] fallback to default translation for: Format/Partition your Devices and manage Mountpoints
[DeviceManager] fallback to default translation for: Device Manager - Fast Mounted Remove
[DeviceManager] fallback to default translation for: Quick and safe remove for your mounted devices
[NetworkBrowser] fallback to default translation for NetworkBrowser
[NetworkBrowser] fallback to default translation for Search for network shares
[NetworkBrowser] fallback to default translation for MountManager
[NetworkBrowser] fallback to default translation for Manage network shares
[NetworkBrowser] fallback to default translation for Mount again
[NetworkBrowser] fallback to default translation for Attempt to mount shares again
[NetworkBrowser] fallback to default translation for Mount shares again
[spzCAMD] Started
[EPG download MediaHighway] Starting up Version
[CI_Assignment] activating ci configs:
[CI_Activate] FOUND 1 CI Slots
[CI_Activate_Config_CI0] no config file found
[CI_Activate_Config_CI0] error parsing xml...
[LED-GIGA] sessionstart
[spzCAMD] Started
[LED-GIGA] Starting !!
[LED-GIGA] initializing
[LED-GIGA] initVFD box = gbultraue
< 780.197166> [EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
< 780.201058> [EPGC] time updated.. start EPG Mainloop
< 780.304222> [ePNG] couldn't open /usr/share/enigma2/distro-logo.png
[Skin] Error: {confluence_openspa/skin.xml}: pixmap file /usr/share/enigma2/distro-logo.png not found!. Please contact the skin's author!
[SCREENNAME] SecondInfoBar
[Skin] Attribute not implemented: xposDuration value: 185
[Skin] Attribute not implemented: colorDate value: teal
[Skin] Attribute not implemented: colorDuration value: gris40
[Skin] Attribute not implemented: colorEvent value: frgr
[Skin] Attribute not implemented: xposEvent value: 200
[Skin] Attribute not implemented: xcolorBegin value: tealclaro
[Skin] Attribute not implemented: render value: Label
< 785.057408> main thread is non-idle! display spinner!
[SKIN] No skin to read...
[SCREENNAME] RdsInfoDisplaySummary
warning, skin is missing element pixstateplay in <class 'Screens.PVRState.TimeshiftState'>
warning, skin is missing element pixstatepause in <class 'Screens.PVRState.TimeshiftState'>
RemovePopup, id = ZapError
[Skin] SKIN ERROR in InfoBarSummary: 'ConditionalShowHide' object has no attribute 'text'
< 787.911244> main thread is non-idle! display spinner!
[SCREENNAME] InfoBarSummary
[SCREENNAME] TimeshiftState
< 788.172083> [EPGC] 64506 events read from /hdd/epg.dat
< 788.272975> Setvolume: 100 100 (raw)
< 788.279235> Setvolume: 0 0 (-1db)
[Skin] Attribute not implemented: alphatest value: blend
setValue 50
< 788.825552> Setvolume: 50 50 (raw)
< 788.825712> Setvolume: 32 32 (-1db)
[NTP]: setting E2 time: 1461417782.37
[LED-GIGA] delay init on boot
< 789.445294> ignore unsupported 8bpp -> 16bpp alphablend!
[ePopen] command: route -n | grep eth0
< 789.671922> poll: unhandled POLLERR/HUP/NVAL for fd 35(16)
< 789.672475> poll: unhandled POLLERR/HUP/NVAL for fd 37(16)
< 789.672608> poll: unhandled POLLERR/HUP/NVAL for fd 41(16)
0.0.0.0
192.168
AT plugin not found
SerienRecorder plugin not found
ER plugin not found
[OpenWebif] no plugins to load
[OpenWebif] started on 80
< 789.925129> poll: unhandled POLLERR/HUP/NVAL for fd 35(16)
< 790.114540> service reference for epg query is not valid
< 744.624900> [eDVBAdapterLinux] g1494> loaded 0 channels/transponders and 0 services
[ePopen] command: ('hdparm', 'hdparm', '-y', '/dev/sda')
< 1151.691930> poll: unhandled POLLERR/HUP/NVAL for fd 35(16)
