Bug general Gigablue UHD 4K - Error tuner streaming
Тайна го
5 Nov 2016
1.411
1.365
Imagen : OpenSpa 7.1.003
Receptor: Gigablue UHD 4k
Se adjunta crash log: NO, se adjunta log del proceso
Error: No reproduce streaming o grabacion de un canal en diferente frecuencia
Antena: Un solo LNB
No se si llamarlo bug, o algun complemento que le falta a la imagen:
Imagen Openspa, con configuracion de antena simple con un solo LNB tuner A, tuner B (No configurado), aunque realizadas pruebas con tuner B bucle a tuner A.
No reproduce streaming o grabacion en canal con diferente frecuencia.
Log cuando intento realizar dicho streaming:
dvb/streamserver.cpp:176 notifier [eDVBServiceStream] stream ref: 1:0:19:7536:426:1:C00000:0:0:0: 19:58:03.8679 dvb/dvb.cpp:1156 allocateChannel [eDVBResourceManager] allocate channel.. 0426:0001 19:58:03.8679 dvb/dvb.cpp:1159 allocateChannel [eDVBResourceManager] available channel.. 041a:0001 19:58:03.8680 dvb/sec.cpp:64 canTune direct_connected 1 19:58:03.8680 dvb/sec.cpp:102 canTune canTune 1 19:58:03.8680 dvb/sec.cpp:116 canTune lnb 0 found 19:58:03.8680 dvb/sec.cpp:132 canTune sat 192 found 19:58:03.8680 dvb/sec.cpp:176 canTune ret1 15000 19:58:03.8681 dvb/sec.cpp:222 canTune ret5 15000 19:58:03.8681 dvb/sec.cpp:236 canTune ret 15000, score old 0 19:58:03.8681 dvb/sec.cpp:243 canTune score new 15000 19:58:03.8681 dvb/sec.cpp:256 canTune final score 15005 19:58:03.8681 dvb/dvb.cpp:863 allocateFrontend [eDVBResourceManager] allocateFrontend, score=15005 19:58:03.8681 dvb/sec.cpp:64 canTune direct_connected 0 19:58:03.8682 dvb/sec.cpp:102 canTune canTune 4 19:58:03.8682 dvb/sec.cpp:116 canTune lnb 0 found 19:58:03.8682 dvb/sec.cpp:132 canTune sat 192 found 19:58:03.8682 dvb/sec.cpp:176 canTune ret1 15000 19:58:03.8682 dvb/sec.cpp:189 canTune ret2 15015 19:58:03.8682 dvb/sec.cpp:222 canTune ret5 15015 19:58:03.8682 dvb/sec.cpp:236 canTune ret 15015, score old 0 19:58:03.8683 dvb/sec.cpp:243 canTune score new 15015 19:58:03.8683 dvb/sec.cpp:256 canTune final score 15015 19:58:03.8683 dvb/dvb.cpp:863 allocateFrontend [eDVBResourceManager] allocateFrontend, score=15015 19:58:03.8683 dvb/sec.cpp:64 canTune direct_connected 0 19:58:03.8684 dvb/sec.cpp:102 canTune canTune 8 19:58:03.8684 dvb/sec.cpp:116 canTune lnb 0 found 19:58:03.8684 dvb/sec.cpp:132 canTune sat 192 found 19:58:03.8684 dvb/sec.cpp:176 canTune ret1 15000 19:58:03.8684 dvb/sec.cpp:189 canTune ret2 15015 19:58:03.8684 dvb/sec.cpp:222 canTune ret5 15015 19:58:03.8685 dvb/sec.cpp:236 canTune ret 15015, score old 0 19:58:03.8685 dvb/sec.cpp:243 canTune score new 15015 19:58:03.8685 dvb/sec.cpp:256 canTune final score 15015 19:58:03.8685 dvb/dvb.cpp:863 allocateFrontend [eDVBResourceManager] allocateFrontend, score=15015 19:58:03.8685 dvb/frontend.cpp:591 openFrontend opening frontend 2 19:58:03.8709 dvb/frontend.cpp:2627 tune (2)tune 19:58:03.8710 dvb/sec.cpp:64 canTune direct_connected 0 19:58:03.8710 dvb/sec.cpp:102 canTune canTune 4 19:58:03.8710 dvb/sec.cpp:116 canTune lnb 0 found 19:58:03.8710 dvb/sec.cpp:132 canTune sat 192 found 19:58:03.8711 dvb/sec.cpp:176 canTune ret1 15000 19:58:03.8711 dvb/sec.cpp:189 canTune ret2 15015 19:58:03.8711 dvb/sec.cpp:222 canTune ret5 15015 19:58:03.8711 dvb/sec.cpp:236 canTune ret 15015, score old 0 19:58:03.8711 dvb/sec.cpp:243 canTune score new 15015 19:58:03.8711 dvb/sec.cpp:256 canTune final score 15015 19:58:03.8711 dvb/sec.cpp:1023 prepare RotorCmd ffffffff, lastRotorCmd ffffffff 19:58:03.8712 dvb/sec.cpp:1244 prepare takeover_sec 0 19:58:03.8712 dvb/sec.cpp:1248 prepare waittakeover_sec 2 19:58:03.8712 dvb/frontend.cpp:2587 prepare_sat [eDVBFrontend] prepare_sat System 1 Freq 10906000 Pol 1 SR 22000000 INV 2 FEC 2 orbpos 192 system 1 modulation 2 pilot 2, rolloff 0, is_id 0, pls_mode 0, pls_code 1 19:58:03.8713 dvb/frontend.cpp:2593 prepare_sat tuning to 1156 mhz 19:58:03.8713 dvb/dvb.cpp:1614 frontendStateChanged [eDVBChannel] OURSTATE: tuner 2 tuning 19:58:03.8713 dvb/pmt.cpp:975 tuneExt allocate Channel: res 0 19:58:03.8714 dvb_ci/dvbci.cpp:783 addPMTHandler [eDVBCIInterfaces] addPMTHandler 1:0:19:7536:426:1:C00000:0:0:0: 19:58:03.8714 dvb/dvb.cpp:2132 getDemux [eDVBChannel] getDemux cap=00 19:58:03.8714 dvb/dvb.cpp:960 allocateDemux [eDVBResourceManager] allocate demux cap=00 19:58:03.8715 dvb/dvb.cpp:1100 allocateDemux [eDVBResourceManager] allocating demux adapter=0, demux=1, source=2 fesource=2 19:58:03.9652 service/servicedvbstream.cpp:127 doRecord [eDVBServiceStream] try it again when we are tuned in 19:58:03.9664 dvb/frontend.cpp:2033 tuneLoopInt [SEC-Slave] tuner 0 start takeover frontend 19:58:03.9711 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9712 dvb/frontend.cpp:2071 tuneLoopInt [SEC-Master] tuner 2 WAIT_TAKEOVER 19:58:03.9715 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9762 dvb/frontend.cpp:1981 tuneLoopInt [SEC] set static current limiting 19:58:03.9763 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9763 dvb/frontend.cpp:1930 tuneLoopInt [SEC] invalidate current switch params 19:58:03.9763 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9764 dvb/frontend.cpp:1580 setSecSequencePos set sequence pos 3 19:58:03.9764 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9764 dvb/frontend.cpp:1580 setSecSequencePos set sequence pos 3 19:58:03.9764 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9765 dvb/frontend.cpp:1940 tuneLoopInt [SEC] update current switch params 19:58:03.9765 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9812 dvb/frontend.cpp:1752 tuneLoopInt [eDVBFrontend] tuner 2 startTuneTimeout 5000 19:58:03.9812 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9813 dvb/frontend.cpp:1745 tuneLoopInt [eDVBFrontend] tuner 2 setFrontend: events enabled 19:58:03.9813 dvb/frontend.cpp:2152 setFrontend [eDVBFrontend] setting frontend 2 events: on 19:58:03.9814 dvb/frontend.cpp:871 feEvent (2)fe event: status 0, inversion off, m_tuning 1 19:58:03.9814 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:03.9814 dvb/frontend.cpp:1643 tuneLoopInt [eDVBFrontend] tuner 2 sleep 500ms 19:58:04.2426 dvb/frontend.cpp:871 feEvent (2)fe event: status 1, inversion off, m_tuning 2 19:58:04.4814 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:04.4816 dvb/frontend.cpp:1981 tuneLoopInt [SEC] set dynamic current limiting 19:58:04.4817 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:04.4818 dvb/frontend.cpp:2117 tuneLoopInt [SEC-Master] tuner 2 RELEASE 19:58:04.4818 dvb/frontend.cpp:2120 tuneLoopInt [SEC-Master] tuner 2 release frontend 19:58:04.4818 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:04.4820 dvb/frontend.cpp:2054 tuneLoopInt [SEC-Slave] tuner 0 end takeover frontend 19:58:08.9812 dvb/dvb.cpp:1638 frontendStateChanged [eDVBChannel] OURSTATE: tuner 2 failed, retune 19:58:08.9813 dvb/frontend.cpp:2627 tune (2)tune 19:58:08.9813 dvb/sec.cpp:64 canTune direct_connected 0 19:58:08.9814 dvb/sec.cpp:102 canTune canTune 4 19:58:08.9814 dvb/sec.cpp:116 canTune lnb 0 found 19:58:08.9814 dvb/sec.cpp:132 canTune sat 192 found 19:58:08.9814 dvb/sec.cpp:176 canTune ret1 15000 19:58:08.9814 dvb/sec.cpp:189 canTune ret2 15015 19:58:08.9814 dvb/sec.cpp:222 canTune ret5 15015 19:58:08.9814 dvb/sec.cpp:236 canTune ret 15015, score old 0 19:58:08.9815 dvb/sec.cpp:243 canTune score new 15015 19:58:08.9815 dvb/sec.cpp:256 canTune final score 15015 19:58:08.9815 dvb/sec.cpp:1023 prepare RotorCmd ffffffff, lastRotorCmd ffffffff 19:58:08.9815 dvb/sec.cpp:1244 prepare takeover_sec 0 19:58:08.9816 dvb/sec.cpp:1248 prepare waittakeover_sec 2 19:58:08.9816 dvb/frontend.cpp:2587 prepare_sat [eDVBFrontend] prepare_sat System 1 Freq 10906000 Pol 1 SR 22000000 INV 2 FEC 2 orbpos 192 system 1 modulation 2 pilot 2, rolloff 0, is_id 0, pls_mode 0, pls_code 1 19:58:08.9816 dvb/frontend.cpp:2593 prepare_sat tuning to 1156 mhz 19:58:08.9816 dvb/dvb.cpp:1614 frontendStateChanged [eDVBChannel] OURSTATE: tuner 2 tuning 19:58:08.9817 dvb/pmt.cpp:109 channelStateChanged tune failed. 19:58:08.9817 service/servicedvbstream.cpp:26 serviceEvent [eDVBServiceStream] STREAM service event 1 19:58:08.9817 service/servicedvbstream.cpp:48 serviceEvent [eDVBServiceStream] failed to tune 19:58:08.9817 service/servicedvbstream.cpp:81 stop [eDVBServiceStream] stop streaming m_state 1 19:58:08.9819 dvb/dvb.cpp:1228 DVBChannelStateChanged [eDVBResourceManager] start release channel timer 19:58:08.9820 dvb/frontend.cpp:2033 tuneLoopInt [SEC-Slave] tuner 0 start takeover frontend 19:58:08.9820 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9820 dvb/frontend.cpp:2071 tuneLoopInt [SEC-Master] tuner 2 WAIT_TAKEOVER 19:58:08.9821 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9822 dvb/frontend.cpp:1981 tuneLoopInt [SEC] set static current limiting 19:58:08.9823 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9823 dvb/frontend.cpp:1930 tuneLoopInt [SEC] invalidate current switch params 19:58:08.9823 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9823 dvb/frontend.cpp:1580 setSecSequencePos set sequence pos 3 19:58:08.9824 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9824 dvb/frontend.cpp:1580 setSecSequencePos set sequence pos 3 19:58:08.9824 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9824 dvb/frontend.cpp:1940 tuneLoopInt [SEC] update current switch params 19:58:08.9825 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9825 dvb/frontend.cpp:1752 tuneLoopInt [eDVBFrontend] tuner 2 startTuneTimeout 5000 19:58:08.9826 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9826 dvb/frontend.cpp:1745 tuneLoopInt [eDVBFrontend] tuner 2 setFrontend: events enabled 19:58:08.9826 dvb/frontend.cpp:2152 setFrontend [eDVBFrontend] setting frontend 2 events: on 19:58:08.9827 dvb/frontend.cpp:871 feEvent (2)fe event: status 0, inversion off, m_tuning 1 19:58:08.9827 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:08.9827 dvb/frontend.cpp:1643 tuneLoopInt [eDVBFrontend] tuner 2 sleep 500ms 19:58:09.2448 dvb/frontend.cpp:871 feEvent (2)fe event: status 1, inversion off, m_tuning 2 19:58:09.4828 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:09.4829 dvb/frontend.cpp:1981 tuneLoopInt [SEC] set dynamic current limiting 19:58:09.4831 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:09.4831 dvb/frontend.cpp:2117 tuneLoopInt [SEC-Master] tuner 2 RELEASE 19:58:09.4831 dvb/frontend.cpp:2120 tuneLoopInt [SEC-Master] tuner 2 release frontend 19:58:09.4832 dvb/frontend.cpp:1615 tuneLoopInt check tuner 0 stats:3 in_use: 1 tmp: -1 19:58:09.4834 dvb/frontend.cpp:2054 tuneLoopInt [SEC-Slave] tuner 0 end takeover frontend 19:58:11.9826 dvb/dvb.cpp:1239 releaseCachedChannel release cached channel (timer timeout) 19:58:11.9829 dvb/dvbtime.cpp:623 DVBChannelStateChanged [eDVBLocalTimerHandler] remove channel 0x1024bb8 19:58:11.9830 dvb/epgcache.cpp:682 DVBChannelStateChanged [eEPGCache] remove channel 0x1024bb8 19:58:11.9831 dvb/dvb.cpp:1222 DVBChannelStateChanged [eDVBResourceManager] stop release channel timer 19:58:14.9883 dvb/frontend.cpp:722 closeFrontend try to close frontend 2
Misma configuracion en imagen oficial OpenMips, si puede realizar streaming de canales en diferente frecuencia o grabar canales, pruebas realizadas hasta en 8 canales diferente frecuencia.
Adjunto log de openmips realizando el streming de un canal de diferente frecuencia:
dvb/streamserver.cpp:176 notifier [eDVBServiceStream] stream ref: 1:0:19:7863:41A:1:C00000:0:0:0: 20:05:26.4304 dvb/dvb.cpp:1102 allocateChannel [eDVBResourceManager] allocate channel.. 041a:0001 20:05:26.4304 dvb/dvb.cpp:1105 allocateChannel [eDVBResourceManager] available channel.. 0426:0001 20:05:26.4307 dvb/frontend.cpp:570 openFrontend [eDVBFrontend] opening frontend 2 20:05:26.4620 dvb/frontend.cpp:2332 tune [eDVBFrontend] (2)tune 20:05:26.4620 dvb/sec.cpp:845 prepare [eDVBSatelliteEquipmentControl] RotorCmd ffffffff, lastRotorCmd ffffffff 20:05:26.4621 dvb/frontend.cpp:2291 prepare_sat [eDVBFrontend] frontend 2 prepare_sat System 1 Freq 10729000 Pol 1 SR 22000000 INV 2 FEC 2 orbpos 192 system 1 modulation 2 pilot 2, rolloff 0, is_id 0, pls_mode 0, pls_code 1 20:05:26.4621 dvb/frontend.cpp:2297 prepare_sat [eDVBFrontend] tuning to 979 mhz 20:05:26.4621 dvb/dvb.cpp:1572 frontendStateChanged [eDVBChannel] OURSTATE: tuning 20:05:26.4622 dvb/pmt.cpp:990 tuneExt [eDVBServicePMTHandler] allocate Channel: res 0 20:05:26.4622 dvb_ci/dvbci.cpp:520 addPMTHandler [eDVBCIInterfaces] addPMTHandler 1:0:19:7863:41A:1:C00000:0:0:0: 20:05:26.4623 dvb/dvb.cpp:2106 getDemux [eDVBChannel] getDemux cap=00 20:05:26.4623 dvb/dvb.cpp:953 allocateDemux [eDVBResourceManager] allocate demux cap=00 20:05:26.4623 dvb/dvb.cpp:1046 allocateDemux [eDVBResourceManager] allocating demux adapter=0, demux=1, source=2 fesource=2 20:05:26.4623 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.5256 service/servicedvbstream.cpp:127 doRecord [eDVBServiceStream] try it again when we are tuned in 20:05:26.5257 dvb/frontend.cpp:1865 tuneLoopInt [eDVBFrontend] set static current limiting 20:05:26.5259 dvb/frontend.cpp:1814 tuneLoopInt [eDVBFrontend] invalidate current switch params 20:05:26.5259 dvb/frontend.cpp:1521 setSecSequencePos [eDVBFrontend] set sequence pos 3 20:05:26.5259 dvb/frontend.cpp:1521 setSecSequencePos [eDVBFrontend] set sequence pos 3 20:05:26.5260 dvb/frontend.cpp:1824 tuneLoopInt [eDVBFrontend] update current switch params 20:05:26.5260 dvb/frontend.cpp:1657 tuneLoopInt [eDVBFrontend] tuner 2 startTuneTimeout 5000 20:05:26.5261 dvb/frontend.cpp:1650 tuneLoopInt [eDVBFrontend] tuner 2 setFrontend: events enabled 20:05:26.5261 dvb/frontend.cpp:1931 setFrontend [eDVBFrontend] setting frontend 2 events: on 20:05:26.5262 dvb/frontend.cpp:798 feEvent [eDVBFrontend] (2)fe event: status 0, inversion off, m_tuning 1 20:05:26.5262 dvb/frontend.cpp:1581 tuneLoopInt [eDVBFrontend] tuner 2 sleep 500ms 20:05:26.7877 dvb/frontend.cpp:798 feEvent [eDVBFrontend] (2)fe event: status 1f, inversion off, m_tuning 2 20:05:26.7877 dvb/dvb.cpp:1568 frontendStateChanged [eDVBChannel] OURSTATE: ok 20:05:26.7878 dvb/dvbtime.cpp:674 DVBChannelStateChanged [eDVBLocalTimerHandler] channel 0xfd9378 running 20:05:26.7878 dvb/dvb.cpp:2106 getDemux [eDVBChannel] getDemux cap=00 20:05:26.7878 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7879 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=20 20:05:26.7883 dvb/epgcache.cpp:674 DVBChannelStateChanged [EPGC] channel 0xfd9378 running 20:05:26.7883 dvb/dvb.cpp:2106 getDemux [eDVBChannel] getDemux cap=00 20:05:26.7884 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7884 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7884 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7885 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7885 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7886 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7886 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7886 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7887 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7887 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7887 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7888 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7888 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7889 dvb/epgcache.cpp:2053 startChannel [eEPGCache] next update in 59 min 20:05:26.7890 dvb/dvb.cpp:1168 DVBChannelStateChanged [eDVBResourceManager] stop release channel timer 20:05:26.7890 dvb/dvb.cpp:2106 getDemux [eDVBChannel] getDemux cap=01 20:05:26.7890 dvb/dvb.cpp:953 allocateDemux [eDVBResourceManager] allocate demux cap=01 20:05:26.7890 dvb/dvb.cpp:1023 allocateDemux [eDVBResourceManager] allocating shared demux adapter=0, demux=1, source=2 20:05:26.7891 dvb/pmt.cpp:77 channelStateChanged [eDVBServicePMTHandler] ok ... now we start!! 20:05:26.7891 service/servicedvbstream.cpp:26 serviceEvent STREAM service event 5 20:05:26.7891 service/servicedvbstream.cpp:127 doRecord [eDVBServiceStream] try it again when we are tuned in 20:05:26.7892 dvb/cahandler.cpp:267 registerService [eDVBCAService] new service 1:0:19:7863:41A:1:C00000:0:0:0: 20:05:26.7892 dvb/cahandler.cpp:285 registerService [eDVBCAService] add demux 1 to slot 0 service 1:0:19:7863:41A:1:C00000:0:0:0: 20:05:26.7910 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7911 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=0 20:05:26.7914 service/servicedvbstream.cpp:26 serviceEvent STREAM service event 6 20:05:26.7914 service/servicedvbstream.cpp:31 serviceEvent [eDVBServiceStream] tuned.. m_state 1 m_want_record 1 20:05:26.7915 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7915 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=18 20:05:26.7919 dvb/demux.cpp:646 eDVBRecordStreamThread [eDVBRecordStreamThread] allocated 40 buffers of 188 kB 20:05:26.7919 service/servicedvbstream.cpp:149 doRecord start streaming... 20:05:26.7920 service/servicedvbstream.cpp:332 recordCachedPids [eDVBServiceStream] no cached pids found 20:05:26.7921 service/servicedvbstream.cpp:202 doRecord STREAM: have 1 video stream(s) (00ab), and 1 audio stream(s) (0092), and the pcr pid is 00ab, and the text pid is ffffffff 20:05:26.7921 service/servicedvbstream.cpp:369 recordPids [eDVBServiceStream] ADD PID: 0000 20:05:26.7922 service/servicedvbstream.cpp:369 recordPids [eDVBServiceStream] ADD PID: 0012 20:05:26.7922 service/servicedvbstream.cpp:369 recordPids [eDVBServiceStream] ADD PID: 0014 20:05:26.7922 service/servicedvbstream.cpp:369 recordPids [eDVBServiceStream] ADD PID: 0092 20:05:26.7922 service/servicedvbstream.cpp:369 recordPids [eDVBServiceStream] ADD PID: 00ab 20:05:26.7929 base/ioprio.cpp:80 setIoPrio [setIoPrio] realtime level 7 ok 20:05:26.7929 dvb/filepush.cpp:330 thread [eFilePushThreadRecorder] THREAD START 20:05:26.7932 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7933 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=0 20:05:26.7945 dvb/pmt.cpp:207 PATready [eDVBServicePMTHandler] PATready 20:05:26.7945 dvb/pmt.cpp:244 PATready [eDVBServicePMTHandler] use pmtpid 0413 for service_id 7863 20:05:26.7945 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7946 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1043 20:05:26.7950 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.7950 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=0 20:05:26.7998 service/servicedvbstream.cpp:26 serviceEvent STREAM service event 5 20:05:26.7998 service/servicedvbstream.cpp:149 doRecord start streaming... 20:05:26.7998 service/servicedvbstream.cpp:332 recordCachedPids [eDVBServiceStream] no cached pids found 20:05:26.8003 service/servicedvbstream.cpp:202 doRecord STREAM: have 1 video stream(s) (00ab), and 2 audio stream(s) (0092, 0093), and the pcr pid is 00ab, and the text pid is ffffffff 20:05:26.8004 service/servicedvbstream.cpp:369 recordPids [eDVBServiceStream] ADD PID: 0093 20:05:26.8005 service/servicedvbstream.cpp:369 recordPids [eDVBServiceStream] ADD PID: 0413 20:05:26.8007 dvb_ci/dvbci.cpp:600 gotPMT [eDVBCIInterfaces] gotPMT 20:05:26.8007 dvb/cahandler.cpp:624 buildCAPMT [eDVBCAService] don't build/send the same CA PMT twice 20:05:26.8008 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.8008 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1043 20:05:26.8506 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.8511 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1027 20:05:26.8527 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.8530 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=17 20:05:26.8608 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.8608 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1028 20:05:26.8761 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:26.8762 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1029 20:05:27.0263 dvb/frontend.cpp:1865 tuneLoopInt [eDVBFrontend] set dynamic current limiting 20:05:27.0317 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.0318 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1030 20:05:27.0832 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.0833 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1031 20:05:27.1083 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.1084 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1033 20:05:27.1316 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.1317 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1038 20:05:27.1520 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.1521 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1039 20:05:27.1590 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.1590 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1041 20:05:27.1816 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.1817 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1043 20:05:27.2022 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:27.2022 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=1044 20:05:27.4817 dvb/pmt.cpp:939 SDTScanEvent [eDVBServicePMTHandler] sdt update done! 20:05:29.3230 dvb/dvbtime.cpp:478 updateTime [eDVBLocalTimerHandler] Transponder time is 04.07.2017 20:05:28 20:05:29.3230 dvb/dvbtime.cpp:491 updateTime [eDVBLocalTimerHandler] diff is -1 20:05:29.3231 dvb/dvbtime.cpp:494 updateTime [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time 20:05:29.3231 dvb/dvbtime.cpp:49 setRTC [eDVBLocalTimerHandler] set RTC Time 20:05:29.3232 dvb/dvbtime.cpp:40 noRTC [eDVBLocalTimerHandler] Boxtype = [quad4k] 20:05:29.3233 dvb/dvbtime.cpp:564 updateTime [eDVBLocalTimerHandler] update RTC 20:05:29.3234 dvb/dvbtime.cpp:584 updateTime [eDVBLocalTimerHandler] time update to 20:05:28 20:05:29.3234 dvb/dvbtime.cpp:587 updateTime [eDVBLocalTimerHandler] m_time_difference is -1 20:05:29.3234 dvb/dvbtime.cpp:591 updateTime [eDVBLocalTimerHandler] set Linux Time 20:05:28.3234 dvb/dvbtime.cpp:602 updateTime [eDVBLocalTimerHandler] time after update is 20:05:28 20:05:28.3237 dvb/dvb.cpp:2106 getDemux [eDVBChannel] getDemux cap=00 20:05:31.0763 dvb/demux.cpp:65 openDemux [eDVBDemux] open demux /dev/dvb/adapter0/demux1 20:05:31.0764 dvb/demux.cpp:251 start [eDVBSectionReader] DMX_SET_FILTER pid=18 20:05:35.0122 gdi/epng.cpp:351 savePNG [ePNG] saving to /tmp/lcd.png"
Antena: Un solo LNB
Log cuando intento realizar dicho streaming....
Adjunto log de openmips realizando el streming de un canal de diferente frecuencia.....
Una pregunta, en las 2 configuraciones (imagenes), los tuner estan igual configurados?
Tienes el cable de antena al Tuner A.
Tuner B no configurado.
Y el resto de tuner??????
El deco tiene 2 tuner FBC en placa base que son 8 tuner normales +/- (Tuner A +3, Tuner B+3), cosas a tener en cuenta para su correcto funcionamiento pues no dices nada del resto de tuner que tienes.
Como el Tuner A es un tuner FBC, tiene 3 tuner mas, los otros 3 tuner los tienes en automatico?
Es importante, si no esta asi, no funcionaran los otros 3 tuner que tiene el Tuner A.
Por defecto, no todas las imagenes tienen los mismos ajustes/configuraciones sin mas, repasa lo comentado y cuenta, es por descartar problemas de configuracion de los tuner FBC que tienes.
Aclaro, las opciones que tienes son las mismas, pero no estan igual configuradas, en su momento puse 4 imagenes aparte de la original en el VU+Solo4K para ver el tema de la busqueda ciega y es lo que note.
No tengo este deco, como comento use el VU+Solo4K que es similar con 2 Tuner FBC en placa base, de memoria, en el deco comentado para tener todos OK...
Tuner A.- Configurado para Astra a 19'2ºE.
Tuner B.- Conectado al Tuner A (bucle interno/loop), no se si GigaBlue UHD Quad 4k hace bucle interno, cuidado, si no lo hace, aparte necesitarias un repartidor/splitter/duplexor de 1x2 con paso de corriente para dar señal al Tuner B.
Tuner C, D y E (que estan en el Tuner A) configurados en automatico.
Tuner F, G y H (que estan en el Tuner B) configurados en automatico.
Al tener una sola antena, estas limitado a la polaridad y banda usado por el Tuner A, para el resto de canales.
Puedes sintonizar hasta 8 TP's, luego dependiendo de los canales que tenga cada TP, la limitacion puede ser grabar hasta 16 canales libres/gratis.
Puedes usar la opcion PIP para ver 2 canales de forma rapida y sencilla.
PD:Suerte, ya nos contaras. :leer:
Тайна го
5 Nov 2016
1.411
1.365
Por defecto, no todas las imagenes tienen los mismos ajustes configurados sin mas, repasa lo comentado y cuenta, es por descartar problemas de configuracion de los tuner FBC que tienes.
No tengo este deco, use el VU+Solo4K que es similar con 2 Tuner FBC en placa base.
De memoria, en el deco comentado para tener todos OK...
PD:Suerte, ya nos contaras.:leer:
Gracias por la respuesta:
1. En ambas imagenes Tuner A configuracion simple, automatica, no mas configuraciones.
2. En ambas imagenes Tuner B no configurado (por lo que en ambos casos no intento hacer bucle entre ambos tuner, desconozco si tiene loop interno o no, pero en imagen openmips me realiza streaming entre diferentes frecuencias).
3. El lnb que no lo indique anteriormente no es FBC, por lo que los demas tuner pues no se configuran.
Lo dicho no se si es bug, o que diferencia puede haber con openmips.
Yako
28 Abr 2016
355
38
Hola, yo tengo el GigaBlue 4 k y lo tengo configurado de la siguiente manera:
- Un solo LNB normal, no unicable.
- Un spliter con una entrada, la del LNB y dos salidas, una al tuner A y otra al Tuner B
- Los demas tuner no configurados, del C al H
Las pruebas que he realizado son poner un canal en la TV principal, otro en una tablet con Wiseplay a traves del TunerServe, otro canal en el ordenador a traves de VLC y, dos canales mas grabando en el disco duro del GB.
La activacion de los tuner es la siguiente el A, C,D,E y F, segun muestra en la pantalla, es decir se salta el B, segun Evox, comento que es el ultimo que activa.
A mi me ha funcionado siempre y tanto las grabaciones como el visionado, sin problemas.
Me falta hacer una prueba cambiando la polaridad Horizontal en algun de los que visione, pero supongo que si cambia la polaridad entrará en acción el tuner B?
No, no puedes con tu lnb ver frecuencias horizontales y verticales a la vez, recuerdo que en alguno de los menús puedes elegir por ejemplo para las grabaciones el tunner que elijas, prueba a poner el B.
Yako
28 Abr 2016
355
38
Una aclaración que se me ha pasado:
- La configutración del Tuner A es secilla, astra 19,2 y el tuner B : igual al A
- Naturalmente la imagen Openspa 7.1.0.3
Yako
28 Abr 2016
355
38
Gracias Oscar ,Me lo imaginaba, por eso no lo he intentado aun, me daba miedo cambiar polaridades por el cambio de tensión y no tengo claro si se puede joder el tuner
Ya se que el LNB es normal.
Le puedes hacer una foto a la configuracion de los tuner, gracias.
La respuesta a la duda es si (disculpa es si).
El Tuner A se quedaria sin señal y el Tuner B tendria señal del canal selecionado (no se romperia nada).
Recuerda que tienes un LNB normal, si es normal, es logico que no sea unicable.ñik:
Solo puedes sintonizar la misma banda y polaridad que tenga el Tuner A (con la opcion de conectado al Tuner A).
Como no comentas que configuracion tiene el Tuner A, seguramente tienes la misma en el Tuner B.
Para hacer lo que quieres, tendrias que poner un LNB unicable.
Con el LNB normal que tienes, ahora esta por el splitter el reparto de señal a los 2 tuner A/B, si tiene la opcion el Tuner B de conectado al Tuner A, miraste si funciona? asi podrias quitar el splitter.
PD: Personalmente prefiero decirle que satelite tiene el tuner conectado.
PD2: No vi las respuestas al estar al telefono, el resto vale.
Тайна го
5 Nov 2016
1.411
1.365
Las fotos en openspa lo tengo asi:
Tuner A
En openmips lo tengo asi:
TUNER A
No creo que tenga nada que ver la configuracion, por que ya te digo que estan configurado el tuner A igual, y el resto de tuner tal cual vienen por defecto o sea no configurados.
Añadir que probada openatv 6.1 ultima version, y con la misma configuracion tambien puede realizar streaming o grabar varios canales de diferentes frecuencias:
El tema de los tuner C, D, E, F, G y H que indicas "no configurados", realmente, como se ve en la foto "se configura automaticamente para FBC", si estan configurados (suena a coña pero es cierto).
Por las fotos, parece la misma configuracion en las 2 imagenes.
Descartada la parte de la configuracion de los tuner, suerte con el deco que tienes.
PD: Por curiosidad, pondre la ultima al VU+Solo4K, me pica la curiosidad.
Тайна го
5 Nov 2016
1.411
1.365
Es posible que sea una cosa solamente de Gigablue 4K con imagen openspa (ya que en las otras imagenes openmips, openatv), no me ocurre. El receptor lleva poco tiempo en el mercado, por lo que todavia faltaran cosillas por pulir.
Yako
28 Abr 2016
355
38
Para una mejor comprensión paso las fotos de la configuración de los tuner y la activación "curiosa" que hace GB de los diferentes tuner:
- Configuración
Viendo 3 canales de diferentes frecuencias:
Y la gestion que hace de los tuner:
Y si añado dos grabaciones :
Es muy curioso como va activando los tuners :)
Yako
28 Abr 2016
355
38
Bueno, con tanto tuner, tantos LNB, etc, me he perdido :( una pregunta cual es el problema con el que se inicio el post?
Entiendo que no puede grabar o ver otro canal con los sintonizadores del GB y la imagen openspa, no?
Si es así yo si que veo y grabo hasta ocho canales con mi GB y openspa, igual estoy equivocado, si?
Tienes razon, sobra el post (lo borro para no liar).
Resumen.
Con imagen OpenSpa 7.1.003 el compañero Тайна no puede.
Con imagen Openmips el compañero Тайна si puede.
Le pedi que revisara la confguracio de los tuner.
Si puedes ver/grabar 8 canales de distintos tp's (por ejemplo), lo tienes bien configurado con Openspa.
Yako
28 Abr 2016
355
38
Pero entonces, no es un bug de la imagen openspa no?
4.960
Si Yako algo diferente tenemos a OpenMips que hace ke funcionen diferente los tuners cuando solo esta conectada antena al tune A y el B esta sin configurar, lo miraremos con calma, ahora estamos liados con cosas mas serias asi ke coje fuerzas ke en nada tendras curro jejejejeje.
Salu2
Enviado desde Tapatalk 2
4.960
Fijado para la proxima version a falta de retoques y mejoras, probado con solo un cable de antena al tuner A y tune B como No configurado, el resto en automatico, en los mismos canales del primer post.
Yako
28 Abr 2016
355
38
Perfecto,
adios spliter y me ahorro los 70 euros, mas o menos, de un LNB unicable.
:bravo:
Perfecto,
:bravo:
El spliter de 2 sale por 4-6€uros.
El LNB unicable de 24 sale 40€ mas portes, pero no tiene tanto juego, claro que puedes sintonizar cualquier canal de todo el satelite, da igual la polaridad y banda.
En las pruebas con la primera imagen juraria que realice un PIP y se puso en el Tuner A y B, esta tarde con la nueva imagen cargada, al hacer PIP lo hace con el Tuner A y C, ya la verdad tengo dudas, al realizar grabaciones la secuencia es....
Primero Tuner A, segundo Tuner C, tercero Tuner B, despues el resto en orden.
Luego cargare un backup para comparar.
Si alguno configura el Tuner B, como conectado al Tuner A, podra ver que despues del Tuner A, curra el Tuner C y despues el Tuner B.
Confirmado al 100%, una fotos al final.
Recordar, si configuras el Tuner B como no conectado.- No lo usa (normal).
Recordar, si configuras el Tuner B como igual al Tuner A ó lo configuras con uno Astra a 19'2ºE .- Lo usa el ultimo al pensar que es otra antena.
El Tuner B sintoniza TVGA, es el 3º tuner en uso, despues de usar el Tuner C. (secuencia A, C y B)
PD: Dejo esta parte aqui, continuo en el otro post.
