- 9 Abr 2009
- 272
- 11
Lo que nos espera
# FIXED
- Records of HD-Channel are freezing about all 10 Seconds. Tone also is less.
Often this is also at recording from SD-Channe
- When playing recorded contents on movie player, "Unsupported format" window is popup, to infinity
- Subtitles are fail on following channels
TP 10892Mhz 27500 SID 4801 V160 A80 // CANAL+
TP 10892Mhz 27500 SID 4802 V161 A84 // CANAL+ FILM
TP 10892Mhz 27500 SID 4805 V164 A96 // Ale Kino!
- Channel scanning of DVB-T/C NIT is not working
- When playing some MOV contents, STB hangs up
- SmartCard is sometimes reset
- From the EPG pressing OK and then select PLAY to zap to a channel totally block the AZbox
(when the program is currentely broadcasting)
- In manual time setting, GMT is not effective
- Inaccurate synchronization of subtitles on Astara 28.2E
- Invalid screen capture on 4:2:2 feeds
# ADDED
- Added "subtitle off" option in setting
- Added "audio default" option in setting
- Freesat EPG is supported
- Screen capture on movie player
- At setting menu, more options for audio are created, like:
DTS: PCM <--> RAW
AC3: PCM <--> RAW
AAC: PCM <--> RAW
Others: PCM <--> RAW
Best Regards,
The OpenSAT/AZBox Team
# FIXED
# ADDED
DTS: PCM <--> RAW
AC3: PCM <--> RAW
AAC: PCM <--> RAW
Best Regards,
