Hi Everyone
On the Qviart Dual if you use deep standby the box does not shut down correctly. The blue light does not go off and the box cannot be re-activated until it is switched off via the switch at the back and turned back on. Its has been like this for the last number of builds. I have reported it but I never get a response.
Hello everyone
On Qviart Dual, if you use deep standby, the box does not turn off properly. The blue light does not turn off and the box cannot be reactivated until it is turned off using the switch on the back and turned on again. It's been like this for the last few builds. I have reported it but never get a response.
Hello everyone
