EVOVDR2 on Spark
rachidcool77
17 Ene 2012
53
30
Im finding this image...not tested yet:
Für Edision Argus Pingulux, PinguluxPlus, GM990, Amiko Alien SHD 8900 u.v.m.
geflasht wirds wie EVOLUX!
EvoVDR2 onlineUpdate-Version=2.00.3
inhalt:
- ntrino-hd wie gehabt mit allen features inkl update
- vdr-1.7.28-hd
(deutsch eng only)
known vdr-bugs:
- dolby geht nur nach 1maligen zap bei Umstellung.
Evolux Version=2.00.3
- ONLINEUPDATE:
(oupdate only possible by ntrino!!)
(for switch back from vdr to ntrino: "rm /etc/.start_vdr && reboot -f")
- VDR:
- rcS fix bind sda2
Evolux Version=2.00.2
- ONLINEUPDATE:
- VDR:
- dolby digital fixxed (if change audio please zap)
- add ard+zdf hd new transponders to S19.2E.tpl
download:
http://is.gd/wdEmSR
rachidcool77
17 Ene 2012
53
30
howto_flash_yaffs2
### HOWTO #####################################################
Content:
A. : flash Evolux-img
-deutsche howto-übersetzung ab zeile 100-
@your own risk!
no warranty if you damage your box!!
READ CAREFULL!!!
YOU MUST HAVE ORIG-SPARK VERSION >=1.2.09 IN BOX!!
### FLASH EVOLUX ##############################################
FLASH EVOLUX:
- format usb-stick with fat/fat32
- copy from "BootargsPack":
       both folder "/bin + /etc" into usb-stick-folder "enigma2"
- copy "uImage" + "e2yaffs2.img + flash_E2_yaffs2.sh" into usb-stick-folder "enigma2"
- connect usb-stick to box-usb-port
- BOOT ORIG-SPARK
if you have allready old EVOLUX-YAFFS2 in flash no worry...
script will check args and reset them if needed back to JFFS2!
telnet pingulux-ip
user: root
pw: root
check if stick correct mounted:
ls /storage/c/enigma2
(if you see uImage, e2yaffs2.img and "bin" + "etc" all fine)
now we start flashing by:
/storage/c/enigma2/flash_E2_yaffs2.sh
are you sure? start flashing EVOLUX now (Y/n) ?
select:
    y
that takes around 1-2 minutes
till finished box reboot auto
     and Evolux-Neutrino should booting...
on firstboot when asked 1 or exit (1=scart, any other button=hdmi) make your choice
EVOLUX-IMAGES CAN ONLY BE FLASHED BY:
         BOOT ORIG-SPARK + flash_E2_yaffs2.sh!
YOUR ORIG BOOTARGS WILL BE SAVED TO STICK/myBootargs.txt ,
SO YOU CAN IF SOMETHING WRONG USE COMCABLE TO FIX
### END ######################################################
### ANLEITUNG #################################################
Inhalt:
1. : flash evolux-img
@auf eigenes Risiko!!!
keinerle Garantie wenn ihr eure Box killed!
ALLES SEHR AUFMERKSAM LESEN!!!
ORIG-SPARK VERSION >=1.2.09 MUSS SICH AUF EURER BOX BEFINDEN!!
FLASH EVOLUX:
- usb-stick mit fat/fat32 formatieren
- "BootargsPack"-Inhalt:
       beide Ordner "/bin + /etc" auf Stick in Ordner "enigma2" kopieren
- "uImage" + "e2yaffs2.img + flash_E2_yaffs2.sh" auf Stick in Ordner "enigma2" kopieren
- usb-stick an box stecken
- ORIG-SPARK booten lassen
habt ihr bereits ein "altes" EVOLUX-YAFFS2 img im flash so überprüft das script dies
und setzt ggfls die args wieder auf JFFS2!
telnet pingulux-ip
user: root
pw: root
überprüfen ob stick korrekt gemounted wurde:
(wenn ihr "uImage", "e2yaffs2.img" und "bin" + "etc" seht is alles korrekt)
flashvorgang starten mit:
Auswahl:
    y
dauert ca. 1-2 minuten
wenn fertig bootet box automatisch neu
     und Evolux-Neutrino sollte booten...
bei firstboot wenn nach 1 / exit fragt (1=scart, jede andere Taste=hdmi) trefft eure wahl!
EVOLUX-IMAGES LASSEN SICH AUSSCHLIESSLICH NUR FLASHEN VIA:
         ORIG-SPARK booten + flash_E2_yaffs2.sh!
Alle anderen "gherkömmlichen images können wie gehabt via:
usb+frontpanel-tasten gefahrlos geflasht werden!
Eure ORIG BOOTARGS werden VOR änderung gesichert am stick als "myBootargs.txt"
wenn also was nich passt könnt ihr dann darüber mit euren comcable+terraterm+bootargskenntnissen notfalls die bootargs wieder auf "standard" setzen
### DEUTSCH ENDE #############################################
Spartacus5000
5 Dic 2011
145
17
Test to GM 990: upgrade sucesfull, but start stb to displey only "boot" not work.
Reactions: LSL
Spartacus5000
5 Dic 2011
145
17
original spark 1.2.09 and upgrade this sw and only displey "boot" not work to GM 990
