TECHNICAL SPECIFICATIONS
Tuner & Channel
Input connector: Typ-F (Female), IEC 189-24
Input frequency range: 950 to 2150 MHz
Input impedance: 75 Ω
Signal level: -65 to -25 dBm
Loop through: Yes
LNB supply
Vertical: + 13.5 V ± 1 V
Horizontal: + 18.5 V ± 1 V
Current: Max. 500 mA
DiSEqC control: Version: 1.0
Symbol rate: 2 - 45 Ms/s
MPEG Transport Stream A/V Decoding
Aspect ratio: 4:3 / 16:9
Data In/Out
RS232: 9 pin D-sub, male
RF Modulator
RF Output channel: UHF CH 21...69, configurable in OSD menu
Processor and Memory
System SDRAM: 4 Mbyte
Video / OSD memory: 2 Mbyte
Flash memory: 2 Mbyte
Power supply
Input voltage: 90 - 250 VAC , 50 Hz / 60 Hz
Power consumption: Max. 30 W
Type: Switching mode adaptor
Physical specification
Size (WxHxD): 320 x 60 x 230 mm
Weight (net): 2.5 Kg
Front panel
Display: 4 digit 7-segment display
****: On / Standby ; Channel Up / Down
FEATURES
• MPEG-2 Digital & Fully DVB Compliant
• Supports Digital reception within single receiver SCPC and MCPC support
• Wide symbol rate of 2 to 45 Ms/s
• DiSEqC 1.0 and 1.2 are available
• Easy graphic user interface
• Multiple channel editing modes
• Multiple Satellite search mode (up to 8 satellites at a time)
• Multiple favourite channel listing function
• Languages for OSD: German, French, English, Arabic, Russian, and more
• Increased conceivability with UHF loop-through
• Supports letterbox, subtitle and teletext
• Supports SPIG (Simple Programme Information Guide) and Extended EPG
• Over 4000 programmable TV and Radio channels
• 256 full colour OSD
• Exciting games
Tuner & Channel
Loop through: Yes
LNB supply
Data In/Out
RF Modulator
Power supply
Front panel
FEATURES
• Exciting games
