es que el Azbox utilisa la misma método de "sharing" de el Dreambox? por favor Help.
ielber
30 Dic 2009
112
es que el Azbox utilisa la misma método et ficheros de "sharing" de el Dreambox? por favor Help.
quiero decir, es que es possible de copiar el fichero Cccam.cfg desde el dreambox hacia el Azbox???
y es que el Azbox utilisa los mismos servidores de compartir del dreambox??
Bongo182
11 Jul 2009
what do you need?
you have a dream and a azbox isnt?
you only have to install cccam in azbox and copy the cccam.cfg from dream in the correct path of azbox.
if you need more help ask me again.
good look
ielber
30 Dic 2009
112
Bongo182 dijo:
what do you need?
good look
I have a dreambox 500s (not HD) subscribed to a sharing server.., and I want to buy an HD box, I found AZBOX and others like Dreambox 800, and I want to get azbox,
some one told me that the azbox use other sharing way and servers...and that's the reason of my question,
now can you tell more about sharing on azbox, when I got a new azbox just unboxed and a cccam.cfg file can you tell me all steps that should I follow or patchs or programs that sould I use to get the sharing works plz in details??
ielber
30 Dic 2009
112
jomatoes dijo:
Hello ielber, you'd better take a look to this post:
[URL]http://www.azboxhd.es/foro/english/1493-alternative-all-one-needs-know-about-azbox-hd-detailed-guide.html[/URL]
Read this article carefully. I think it'll be very helpful to you. After that, if you have any doubt, ask in that section (the english section)
Best regards :thumbsup:
So complicated, can you explain in a simple way plz, I have a dreambox using a Cccam.cfg and I want to transfer that file to work with the Azbox, can you confirm and explain all steps in the link you gived me cos there are a lot of symboles that i could not understand like K_Ks.......and can I do all these steps under original image of the Azbox without any chages?? help me to decide and to chose between Azbox premium HD and Dreambox 800 hd
jomatoes
3 Abr 2009
418
ESPAÑA
ielber dijo:
You can use cccam 2.1.1 (for instance) and change the cccam.cfg from dreambox to azbox, of course. In azbox there aren't any images like in dreambox (nabilo, kgd, gemini, etc). Azbox uses firms, the last one has just appeared today (0.9.4142)
To install an camd like cccam, you first have to install openxcas.
I don't know what you mean with K_Ks. Be patient and read and read. At the begining all seems too strange for you, but read and read and you'll see everything more clear.
I began with an ibox (dreambox clon) and I have now and azbox. Nobody taugh me, I read and read before buying it. When I had a doubt, then I asked.
