Enigma Signal Meter – Krkadoni Edition
994
First release of Enigma Signal Meter was quite popular, but it was buggy, lacked support for many different Enigma 1 and Enigma 2 flavors, had no support for multitasking, had confusing and different interface for E1 & E2 receivers. That’s why new Enigma Signal Meter – Krkadoni Edition was born.
Description:
Fast, small, portable, simple and free application for Enigma 1 / Enigma 2 satellite receivers, build to help you align you satellite dish to perfection.
Features:
SUPPORTS ALL currently existing Enigma1 and Enigma2 receivers and images
same simple interface used for Enigma1 and Enigma2 boxes (originally they are quite different)
full background processing (running tasks will not hang application)
small & portable (doesn’t require installation and can be run from USB stick)
autoupdate (offers to update when new version is available)
voice reading of signal levels (uses default Windows voice)
signal beeping (beeps signal with frequency depending on signal level)
works remotely (just forward web port and you can connect from anywhere)
Requirements:
Enigma 1 or Enigma 2 based satellite receivers with running Web interface (WebIf)
Network connection between receiver and computer
Windows XP or higher
.NET Framework 3.5
1 MB of free disk space
List of receivers it was tested and working on:
- AzBox Premium
- AzBox HD Elite
- AzBox Ultra HD
Thanks to all people on Satelitski forum who tested.
For best results when searching (faster response time):
- don’t search while zapped on HD channels
- don’t search while recording
- don’t search while receiver’s web interface is open in web browser
- don’t search if you have other plugins running
- generally avoid anything that slows down your receiver.
como es de costumbre en estos casos, la traducción correrá a cargo de Sergiri.
    68,8 KB · Visitas: 86
  • SignalMeter.zip
    399,6 KB · Visitas: 23
waxfuzz
20 Dic 2009
345
57
Primera version de Enigma Signal Meter que fue muy popular, pero tuvo errores, carente por el soporte para diferentes versiones E1 y E2, no tuvo soporte para multitarea, tuvo confusion con diferentes interfaces en receptores E1 E2. Esto es el porque de que Enigma Signal Meter - Krkdoni ha nacido.
Descripción:
Aplicación para receptores E1/E2 rapida, pequeña, portatil, simple y gratis, hecha para ayudar a alinear tu antena de satelite a la pefección.
Características:
Soporta todos las recectores e imagenes de E1/E2
misma interface usada para los receptores E1/E2 ( originalmente eran bastante diferentes )
pequeña y portable ( no requiere instalación y puede ejecutarse desde una memoria USB)
autoupdate ( ofrece actualizar a una nueva versión si esta disponible )
lectura de voz para niveles de señal ( usa la voz de windows predeterminada )
tono de señal ( diferente frecuencia de tono de señal dependiendo del nivel de señal )
funcion remota ( abra el puerto web y podrás conectarte desde cualquier sitio )
Requerimientos:
Receptor de satelite basado en E1 o E2 con el interface web (webif) arrancado.
Conexión de red entre el receptor y el ordenador.
Windows Xp o Superior
.Net Framework 3.5
1 MB libre en disco.
Probado y funcionando en los receptores:
- AzBox Premium
- AzBox HD Elite
- AzBox Ultra HD
Gracias a toda la gente del foro Satelitski que testeó.
Para mejores resultados en la búsqueda ( tiempo rapido de respuesta)
- no busque mientras zapeas en canales HD
- no busque mientras graba
- no busque mientras el interface web esta abierto en el navegador
- no busque si tiene otros plugins en ejecución
- generalmente no haga nada que ralentice su recector.
Mas o menos esto es xD
15.939
jajajaja, mira que estaba leyendo y pensando que te iba a poner, pero veo que piensas rápido ;) Como ya te dije la vez anterior, lástima que ya lo han traducido, que sino... B)
waxfuzz
20 Dic 2009
345
57
pues mi me dice esto : not found any compatible dvb card
994
jajaja, mira que lo intento pero siempre te libras joio
@waxfuzz si tienes razon sorry, me equivoqué al subirlo, subí la versión 006, paso a cambiarlo en el primer post.
