- 22 Ene 2010
- 25
- 39
In this release:
- Change to "Open" position in the last selected folder (you avoid having to go through the whole structure to reach the last folder selected)
- Change to "Save" in the final placement folder (you avoid having to go through the whole structure to reach the last open folder)
- Fixed bug in "Compare" add channels feature DDT (DTT channels are now correctly imported)
- Fixed bug in "to Decoder" error if connection failed (in case of error reading / writing data to the decoder buttons Close / Save are enabled)
- Added package installation (to install you should delete the previous directory - the profiles are not deleted)
- Added Dutch language (thanks h.Verheijden)
