- 5 Ene 2010
- 4.776
- 1.514
DCC-E2 v1.40
Support dFlash *. nfi Image Backup
It is now one of the current backup *. nfi images are created in Flash.
To use this function must be the plugin "dFlash" of gutemine be installed on the box!
The backup image is always created first on the box (the target directory and can optionally
be downloaded to the PC. Upon request, then the backup on the box is cleared.
The path for the backup on the box and will download to a PC and stored in the configuration are set automatically the next time.
Restart Enigma 'send tools / command' to add
This command only starts the GUI, so Enigma (2) new.
Sorting function, and 'Keep Selection "added for packages
The ipkg / opkg packages can now be sorted by clicking on the column header. In addition to the previously selected entry will now jump back, if after you install or remove a plugin, the table is re-read. Reloading is necessary in any case, since DCC can not even detect whether dependent packages have been installed.
Left menu items now part of the resources
These can also be translated into other languages.
You can find these strings in the language file in the [strings] and start with 'menu ...'.
Download Recordings optional inclusive *. eit
Together with Recordings can each be associated *. ince downloaded optional.
The setting is saved and automatically restored after restart.
bugfixes
- The box type was sometimes not properly recognized or incompletely
- Sorting of Records had no function
- Set to 'Active / Passive FTP' had no effect on FTP2 for background actions
- If the query "delete file, are you sure?" terminated with Escape, the file was deleted anyway.
- Improper alignment of the input field for the IP address of the box
bugfixes
