hola alguien podria poner un tutorial para torpes de como meter las chistes en este deco, es que lo acabo de pillar y estoy predido, e puesto el plugin camd oscam, pero luego no atino a comfigurarlo, he seguido estos pasos de jcuevasg ,
pero a mi melen muchos mas
[reader]
label = lan_cccam
description = CCcam LAN connection
protocol = cccam
device = ip del servidor cccam,puerto del servidor cccam
user = user servidor cccam
password = password servidor cccam
group = 4
cccversion = 2.3.0
ccckeepalive = 1
pero a mi melen muchos mas, estos son los que he configurado yo con los datos de mi chiste
#[reader]
#label = remoteccampeer
#enable = 1
#protocol = cccam
#device = cccam.example.cx,12925
#account = user
#password = password
#services = !service1,!service2
# (the ignored providers or channel see oscam.services)
#reconnecttimeout = 5
#group = 12
#lb_weight = 100
#cccmaxhops = 5
#cccreshare = 3
#ccckeepalive = 1
#audisabled = 1
# the best is for NOT sending emm's to remote cccam Leete las normas
#cccversion = 2.2.1
# on cccam it would have been a c line like :
# C: cccam.example.cx 12925 user password no { 0:0:5 }
y estos son todos los que me salen
# oscam.server generated automatically by Streamboard OSCAM 1.00-unstable_svn build #5630
# Read more:
http://streamboard.gmc.to/oscam/browser/trunk/Distribution/doc/txt/oscam.server.txt
#[reader]
#label = lower
#enable = 1
#protocol = internal
#device = 0
#detect = cd
#mhz = 500
#cardmhz = 500
#caid =
#ident =
#services =
#group = 1
#emmcache = 1,3,15
#lb_weight = 100
#cccreshare = 3
#audisabled = 0
# uncomment and enable this lines below only if devices are present
#[reader]
#label = upper
#enable = 0
#device = /dev/sci1
#detect = cd
#mhz = 500
#cardmhz = 500
#caid =
#ident =
#services =
#group = 2
#emmcache = 1,3,15
#lb_weight = 100
#cccreshare = 3
#audisabled = 0
#[reader]
#label = smartreader
#enable = 0
#protocol = mouse
# dreambox kernel does not support smartreader protocol so use mouse and set speed with ttyS0 tool
# for devices boxes with libusb1.0.6 or greater and kernel above 2.6.30 use smartreader
#device = /dev/ttyUSB0
# for smartreader protocol use bus:device
# bus:device bus name and device name of the Smartreader+
# (get the names with lsusb 'Bus' and 'Device')
#detect = cd
#mhz = 600
# do not use with mouse do use with smartreader protocol
#cardmhz = 600
#caid =
#ident =
#services =
#group = 3
#emmcache = 1,3,15
#lb_weight = 100
#cccreshare = 3
#audisabled = 0
# uncomment and adapt to your needs the readers below this line or ad extra ones.
#[reader]
#label = pcserverlocalnetwork
#enable = 1
#protocol = cccam
#device = 127.0.0.1,52000
#account = user
#group = 5
#emmcache = 1,2,15
#lb_weight = 100
#cccversion = 2.2.1
#cccmaxhops = 5
#ccckeepalive = 1
#cccreshare = 3
#audisabled = 0
[reader]
#Label = Camd3Remote1
#Protocol = cs357x
#Device = 127.0.0.1,60000
#User = user
#Password = password
Group = 1
[reader]
label = camd
protocol = camd35
device = 127.0.0.1,60000
user = user
password = password
#services = austriasat
caid = 0D05,0D95
group = 1
#[reader]
#Label = NewcamdRemote1
#Protocol = newcamd
#Device = 127.0.0.1,50001
#User = user
#Key = 0102030405060708091011121314
#Caid = 0D05
#Group = 1
# on cccam it would be a c line like:
#C: 192.168.123.9 12000 user pasword no { 0:0:5 }
#[reader]
#enable = 1
#protocol = cccam
#account = user
#group = 12
#lb_weight = 100
#cccmaxhops = 5
#cccreshare = 3
#ccckeepalive = 1
#audisabled = 1
#cccversion = 2.2.1
PERDON POR EL TOCHO, alguien podria dicirme como configurarlo y si hay que activar algo en el deco despues
GRACIAS
pd esta es la camd que he puesto
