-> http://maximum.info.se
23.02.2007 v1310- ******** (19E) auto roll
- Cabo (30W) auto roll
- ********* (19E) key is editable via remote control
- ORF (19E) fix
01.11.2006 v1302- **** updated
- improved work with Biss channels
04.07.2006 v1262- Channel search improved
- *** key fix
- minor bugs fixed
07.06.2006 v1258- ******** (19E) added
- Cryptoworks support
22.03.2006 v1246
- ********* (19E) key updated
- ****** (13E) fix
- Cabo (30W) fix
26.01.2006 v1232- ********* (19E) fix
- Multivision fix
06.01.2006 v1222- ********* (19E) fix
- Cabo (30W) fix
- Multivision auto roll
- Astra pre-channel list removed
30.12.2005 v1216
- modified OSD and Astra pre-channel list
28.11.2005 v1212- ***Crypt 2 support
AES key is editable via remote control
update **** 01 and 11 for ident 007C00
28.10.2005 v1196- another Cabo fix
D+ (30W) and ****** are down at moment
28.09.2005 v1186- Cabo fix
14.09.2005 v1184- ****** fix
31.08.2005 v1182- Nagra2 D+ (30W) added
14.06.2005 v1160- ****** fix
- Via2 *** added
- Via2 ART added
30.06.2005 v1164
- ****** fix
- Via2 RTVi 01AC00 added
- Via2 PBK 019410 added
12.07.2005 v1166- ****** fix
How To:
1. Switch your Maximum to standby mode
2. Connect PC and Maximum with RS232 (nullmodem) cable
3. Start loader program "CLoader25.exe"
- choose right Com port
- download mode is by default "Execution"
4. Browse for newest firmware file "S_1000MFTA_WP_F306_...._V1196.lha"
!You don't need to unpack it!
5. Start Download
6. Power on your Maximum
7. Loader program shows the progress bar and then "Flash writing"
8. After few minutes the loader program closes and Maximum restarts itself
9. Go to "Insallation" menu, find "Factory Setting" and then choose "Program"
For Pin Code type "0000"
10. For emulator activation press "Menu" and enter "2580" from remote,
then choose the lock mode
"Always off" is a best option
Enjoy!
Tips:
- Key editor is available via help "?" button
- After EVERY firmware change is ALWAYS needed to do a "Factory reset" and activate emulator again
- Channel data and antenna settings can be restored with program Channel Editor "CEdit504.exe"
- Don't use USB-RS232 converter for the firmware loading, a error might accour
- ORF (19E) fix
- *** key fix
- minor bugs fixed
22.03.2006 v1246
- ****** (13E) fix
- Cabo (30W) fix
- Multivision fix
- Cabo (30W) fix
30.12.2005 v1216
- Via2 *** added
- Via2 ART added
30.06.2005 v1164
- ****** fix
How To:
5. Start Download
Enjoy!
Tips:
