Cool TV Guide V5.6.1 by Coolman
Yersi
18 Mar 2007
6.647
793
Multilanguage
for OE 1.6
green = all stations now run
light blue = channel is selected
blue = all channels
red = recording
"Pad"
2 page vertical
8 page down
4 left side
6 page right
also switchen and zapping channels without EPG! (Adjustable)
Pad with quilting, as usual
Reset to 5
Full Reset to 0
1 Zoom in
3 Zoom out
7 Switch 4 guides (adjustable)
Switch 9 to 20 clock
<Day - (Guide-dependent)
> Day + (depending Guide)
red = Zap (adjustable)
Zap langrot = + Exit (adjustable)
green = timer (adjustable + editable)
= green for shipment to the car automatically add timers (adjustable)
yellow = Cool Switch (adjustable)
long yellow bouquet = list (set)
Blue = Cool Search function (adjustable)
long blue = Do Search function (adjustable)
OK = Cool Info Guide (adjustable)
langOK = (adjustable)
Rec = QuickRec
kurzEPG / User Guide = select (zap through all the guides)
HELP = Display all commands
Setup Menu =
TV = Timer List
= Power Off Timer
3D View / Standard View (selectable)
/ Usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/Cool3D /
it has 2 folders
In "Standard" and the graphics are there, they are one of the screens included in CoolTV
In "MyDesign" anyone can download the graphics, which he would like (is empty by default)
In "SkinDesign" Skinner can pack an appropriate graphics to his skin, so this is purely folder directly into the skin
e.g. / Usr/share/enigma2/BlackAlu-Coolman-Mod/SkinDesign /
so now everyone can make their OWN appearance and buttons easily yourself
Cool TV Guide, Guide Tiny Cool, Cool Multi Guide Nice Guide Cool, Cool Info Guide, Cool Single Guide, Easy Guide Cool, Cool University Guide, Cool Search and setup
were stored in an extra CoolSkin folder ...
Thus, you can now change the Skinns without restarting
I also made notes for Skinner, so you can install it simply
in the setup:
You can now assign your own keys ...
since there never was an agreement
the amount of your picons adjustable!
Thus you can define your own cell height and frame
and you can even left the distances and the number of your picons see the set you want!
genause as Picon on and off!
start on channel 1 (adjustable)
Primetime e.g. 20:15 (adjustable)
Font size, columns, timeline are all set!
CoolPico even the size can be changed!
Selectable home screen! Simply select CoolSwitch or 7 have what you want ..
Display of bouquets in the skin
who has bouquets will be happy just with the setup ...
set is also the bouquet display at startup On / Off
But I think it is practical to put his bouquet on a button ...
because the plugin anyway remembers the position and the bouquet ...
super cool is the cool search function ...
Broadcast missed .. or already started?
no problem .. Just press the blue button press and you can see directly where a repeat run!
or you go into the Cool Info Guide
There you have the new CoolSimilar
which shows you for each shipment, whether it is transmitted anywhere again
who has joined his box to the Internet will be pleased with IMDb or TMDb
But you must also help you or even to the IMDb TMDb load of feed ...
Cool Free Tuner
when shots are not selectable transmitter gray
Cool Timer Alarm!
This feature is brand new and has no other EPG
It checks your timer recordings ...
recordings are moved by the transmitter, but are still in time without having to be cut,
then remains the recording Red
But the recording is cut, then the display is yellow!
and there will be a pop-up message with the details shown
So even if you see a yellow uptake, then it is high time to check this!
have fun with it!
the date of CoolPico Littleleo's Black 3D Button Picon
For me the most beautiful
Instructions:
copy the ipk to the TMP and how to install plugins ...
Please note:
requires only the enigma2-plugin-extensions-cooltvguide_Coolman_V5.6.0_all.ipk
Only those who want to have the design ...
which must be the enigma2-plugin-extensions-cooltvguideskin_Coolman_V5.0_all.ipk
down load
Beware of problems or crash:
if you do not see any info in the EPG, or even a crash gets ...
it's because of a non-customized skin!
You either used a different skin,
or changes in the FTP
e.g. / Usr/share/enigma2/EuerSkin/skin.xml
You will find it more
<Screenname = "CoolTVGuide" .........
<Screenname = "CoolTinyGuide" ........
Thus, for each view usually an entry from
changes from the simple to
<Screenname = "xxxCoolTVGuide" .........
<Screenname = "xxxCoolTinyGuide" ........
then it should work
