Despues de realizar todo los pasos para revivir mi Azbox Premium HD se para en el sigiuente paso. Se os ocurre por que puede ser ?
YAMON> go
em86xx_eth ethernet stop
Linux version 2.6.22.19-19-the_ripper (root@debian) (gcc version 4.3.2 (Debian 4 .3.2-1.1) ) #185 PREEMPT Mon May 31 16:44:40 CEST 2010
Configured for SMP863x (revision ES6+/RevA+), detected SMP8634 (revision ES9/Rev C).
Detected CPU/System/DSP Frequencies: 300.37/200.25/300.37MHz
SMP86xx Enabled Devices under Linux/XENV 0x48000000 = 0x00021ace
BM/IDE PCIHost Ethernet I2CM I2CS USB PCIDev2 PCIDev3 SCARD
Valid MEMCFG found at 0x10000fc0.
CPU revision is: 00019069
Determined physical RAM map:
memory: 06be0000 @ 10020000 (usable)
User-defined physical RAM map:
memory: 06ae0000 @ 10020000 (usable)
Wasting 2098176 bytes for tracking 65568 unused pages
Initrd not found or empty - disabling initrd
On node 0 totalpages: 92928
DMA zone: 726 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 92202 pages, LIFO batch:31
Normal zone: 0 pages used for memmap
Built 1 zonelists. Total pages: 92202
Kernel command line: mem=107m console=ttyS0,115200
Primary instruction cache 16kB, 2-way, physically tagged, linesize 16 bytes.
Primary data cache 16kB, 2-way, virtually tagged, cache aliases, linesize 16 byt es
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 2048 (order: 11, 8192 bytes)
Using 150.188 MHz high precision timer.
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 96384k/109440k available (4018k kernel code, 12948k reserved, 1013k data , 4408k init, 0k highmem)
Calibrating delay loop... 295.93 BogoMIPS (lpj=147968)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
tangox: creating TLB mapping for 0x20000000 at 0xc0000000, size 0x08000000.
PCI: Initializing SMP86xx PCI host controller
PCI: Remapped PCI I/O space 0x58000000 to 0xc8020000, size 64 kB
PCI: Remapped PCI config space 0x50000000 to 0xc8004000, size 10 kB
PCI: device 1 disabled
PCI: device 4 disabled
YAMON> go
