Como Configurar La Blanca Para Visionar Y Sacarle Dos N Para Otros 2 Deco Playa
pumuki1
25 Ago 2009
429
6
os comento
en el fichero users.sbox pongo esto:
NC=user1 pass1 slot0 0
NC=user2 pass2 slot0 0
en el fichero sbox.conf pongo esto:
[main]
server_only=0 # 0=mixed mode 1=only server
log=1 # 1=no log 1=log to /tmp/sbox.log //ALWAYS USE 0//
logudp=192.26.1.32:3354 # server ip:server port
userspath=/usr/bin/users.sbox # users list
channelinfo=/usr/bin/sbox.channelinfo # channel info
webinterface=1 # 1=web interface on 0=web interface off
webadmin=user:pass # user:pass for webinterface
webport=8181 # web interface port
rdgserver=0 # 0=radegast server off 1=radegast server on
rdgport=16050 # radegast server port
use_nagra=0 # 1=use as nagra card 0=use as irdeto card (only for nagra over irdeto cards)
prio=1810:004001,000000,004101;0100:004106:3311 # prio caid for dvbapi, caid1:prov1;caid2:prov2:prov1
cccam=0:19000 # 0=cccam server off - 1=cccam server on : cccam server port
betatunnel=0 # 0=betatunnel support disabled 1=betatunnel support enabled
[slot0]
active=1 # 0=inactive 1=active
sci=/dev/sci0 # lower
ncdserver=1 # 0=newcamd server off 1=newcamd server on
deskey=0102030405060708091011121314 # newcamd deskey
port=20000 # newcamd port
mhz=368 # Mhz for card in this reader, DON'T WORK ON PHOENIX INTERFACE. Example: mhz=357, mhz=368
reader=1 # 0=phoenix, 1=sci (internal reader), 2=smartreader
cache=0 # how many ecms can be cached, 0 or less=cache disabled
#Nagra2/3 Example
[xxxxxxx] # nagra2 camid (4 bytes)
rsa=xxxxxxxxxxxxxxxxxxxxxxxxxx # rsa "n" from this card (like newcs)
boxkey=xxxxxxxxxxxxxxxxxx # boxkey from this card
emm=0 # 0=accept all 1=block emms 2=block emmu 4=block emmg
portlist=0 # use portlist or no
portlistpath=/var/****/port.list # path from port.list
y en los dos cccam.cfg a donde les paso mi N les pongo esto
N: ip 20000 user1 pass1 01 02 03 04 05 06 07 08 09 10 11 12 13 14
N: ip 20000 user2 pass2 01 02 03 04 05 06 07 08 09 10 11 12 13 14
el caso es que yo con mi local la visiono bien pero en el sboxadmin control los dos user me salen offline y ellos no ven nada.
como puedo hacerlo?? mi idea es usar una sola camd
gracias
J
jpbravo
Prueba asi :
server_only=1 # 0=mixed mode 1=only server
log=0 # 1=no log 1=log to /tmp/sbox.log //ALWAYS USE 0//
y debes crearte otra n ( NC=user3 pass3 slot0 1 ) y pasarsela al azbox donde la lees instalando tambien CCcam así :
N: 127.0.0.1 20000 user3 pass3 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
salu2
pumuki1
25 Ago 2009
429
6
gracias pero no quiero enlazar sbox con ccam porque se me cae mucho, por eso es la idea de usar solo sbox
J
jpbravo
supongo que tienes abierto el puerto 20000 en el router para la ip del azbox( esta la tienes que poner estatica para que siempre sea la misma) .
salu2
16.771
Tal como dice jpbravo, el problema debe ser que el puerto 20000 no está abierto para la ip del deco donde tienes la tarjeta.
Y supongo que cuando pones ip en las líneas N, te refieres a host dyndns o no-ip.
pumuki1
25 Ago 2009
429
6
si, cuando pongo ip en las líneas N, me refiero a host dyndns o no-ip
por otro lado el puerto 20000 lo tengo abierto para la ip del deco pero nada.......
J
jpbravo
has probado a arrancarlo por telnet? seguramente en el log veras el fallo que te esta dando
killall -9 sbox.mips
cd /usr/bin
./sbox.mips
ahora mira lo que te dice y si no lo sabes interpretar ponlo por aqui pero sin poner datos conprometedores.
salu2
pd: verifica tambien que tienes el dyndns ó no-ip actualizado
Si tu vas a ver por sbox no necesitas poner mas users solo los externos
esta linea en 1 por que es nagra
use_nagra=1 # 1=use as nagra card 0=use as irdeto card (only for nagra over irdeto cards)
por lo demas diria que es tema de puertos a la ip del deco o dyndns
