- 5 Ene 2010
- 4.354
- 994
Chicos os dejo esto para testear:
CCcam Organizer v0.1
Because of card update delay channels may freeze and you may temporarely delete pe*r(s) from which the ecm cames from.
This plugin may be used for this operation and to find fake cards coming from Leete las normas.
Back-up your CCcam.cfg before using.
Usage:
Delete pe*r:
- When the channel is frozen, delete temporarely the peer from which the ecm is coming from.
Recover pe*r:
- Recover temporarely deteled peer.
Find Fakes:
- Delete temporarely all Leete las normas except the peer to test. If the channel for which the card said to be supplied is clear, the card is OK. if not the card is fake or not updated.
Stop Finding Fakes:
- Recover deleted pe*rs and revert to the initial status.
Thx tani1
http://www.megaupload.com/?d=DHC678T8
Usage:
Delete pe*r:
Recover pe*r:
Find Fakes:
Stop Finding Fakes:
Thx tani1
